Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
How do I replace the Electrolux EL7020A powerhead base? I've opened it up and removed all the screws but there is a cable going through the base that's keeping everything in. How do I get the cable through the base? Thanks.
  • nakajimamiyo Jan 03, 2011
    The link did not help at all. The wires are going through a hole in the base. The wires are "stuck" because they can not be removed at either end so there's no way to get the wires through the hole. The only solutions I can see is to cut the wires and splice them back together or to cut the base down to the hole. Both of my solutions **** so I am hoping there is an expert with a better solution.
  • 944 Answers
Hope this will help you out.This contains the body parts fitting diagram which might help you
http://www.ereplacementparts.com/electrolux-el7020a-canister-vacuum-parts-c-109672_109674_109729.html
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 03, 2011
HOW DO CHANGE THE BULB IN MY ELECTROLUX 3000 UPRIGHT VACUUM?
Remove the 5 phillips head screws on the bottom of the base.
Insert a flathead screwdriver into the square holes and release the latches.
Turn vacuum front up.
Lift back of powerhead cover and carefully remove.
Look at light diffuser carefully and remember how it fits. Lift off the light diffuser.
Push bulb in, twist, and remove.
Insert new bulb, push in, twist to lock.
Place diffuser over bulb.
Place front of cover on with the lip in the grooves on the inside of the base.
Settle cover into place, making sure the latches snap into place.
Turn vacuum over and replace screws.
Mar 11, 2011 | Electrolux Epic 3500 Vacuum
The powerhead stop working followed by the entire canister not working. There are no lights and nothing funtions.
this unit is made by eureka
just carrys eletrolux name
the original electrolux is now called aerus
Jul 12, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Where to buy t joint for electolux vacuume EL7020 powerhead?
If you still have your receipt i would recommend to contact electrolux at 800 896 9756 you have a 2 year waranty so they should be able to either replace your power head or refer you to a service station that can repair it
Jun 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The clip that holds the EL5 powerhead to the wand has broken (again). How does one fix this?
i found this part online- search for part # via an exploded parts diagram of your specific unit (via google)
i ordered 5 of them because it always breaks or pops out.
this is a nice machine with crappy parts.
sorry :(
May 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have a new electrolux el7025a-r and it keeps cutting off while I am vacuuming. I am using the small powerhead on hard floors and I have checked the hoses for blockages and the bag is new. I can not...
The wands are notorious for going out on that unit. One or both probably need to be replaced. Try to get it done under warranty if you still have the receipt, but they shouldn't cost you too much if you can't.
Good Luck
Dec 01, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Parking position
I think it only works on the advertisements.
Nov 26, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Oxygen Canister Vac
Did you check the powerhead drive belt. Procedures for replacement are on the electrolux website and also in the owner's manual.
Nov 18, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
79 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
