Question about Panasonic PT-50LCX63 50" Rear Projection Television
Just installed 4th bulb, last one lasted 1.5 years. After shutting off tv the power button will stay lit, when I go to turn tv on later the screen gets partial power then goes black again. Before this new bulb I would have to wait another 10 mins to be able to turn on successfully. It takes multiple times with time in between for it now, please tell me what to do, Thanks!!
  • 2 more comments
  • aintakin01 Jan 04, 2011
    I installed new bulb 1 week ago today. Last night the tv refused to stay on, after probably a dozen tries over a few hours of turning on
  • aintakin01 Jan 05, 2011
    Yes, I replaced the bulb myself. Why exactly? So I should confirm the light bulb housing connection to the tv? Last night I pulled the back cover off the tv, I carefully
    The only thing my tv does now is run the fans which I can clearly see because I have the back cover off. Where
    Is there any way of checking the bulb? It obviously worked for about 6 day when it finally turned on and I pulled it out last night and it was still in one piece. That would be great if it was just the bulb. Anything I can do to check the bulb?
    Genius:
  • 1,274 Answers
How long has the new one lasted.
reply
my
name is
Jonh
Posted on Dec 30, 2010
  • 4 more comments
  • JOHN BABA Jan 04, 2011
    It does not sound like the bulb. Go back and check the connections, (plugs) some times they will work for a while, but then, if they are not snaped in-place, they will begin to fail.
    I failed to ask you! Did you replace that yourself, very important, as there is voltage present ?
  • JOHN BABA Jan 05, 2011
    The DM power board has some bad capacitors or leaking caps. Check for buldged up or puffy
    or swollen caps on the power board. Replace them only with the same rating as the bad ones.
    Get the parts you need here. www.MatsEletronics.com .
    Also check that your fan is working
    then if the bulb is not lite, you have a defective bulb. I would check on the warranty on it.
    There are a few PICO fuses right next to the bulb housing. Check those, they are short, looks like a resistor. You will need a OHM meter to check. If they are good. Then you have a bad bulb
Last night watching tv, picture cut off (black screen) but power light on set stay on. then after bout 30 seconds the power button went off. Turn set back on , powere light lit but no picture and again...
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 10, 2010 | Sanyo DP50747 50 in. Plasma TV
After a period of time, vertical lines appear on the screen. Looks like jail bars. Sometimes turning the TV off, then back on will clear it. All channels. I replaced the projection bulb about 6 months...
no solution, same sounding problem though. last year we were getting lines through the screen and flickering and then the bulb burned out. had it replaced, 2 months later it did it again (they wouldn't stand behind the bulb so we had to buy a whole new one) this time had the bulb and ballast replaced because the repair guy said usually you have to replace both (why didn't they replace them both in the first place?) .. a year later and it's doing it again.. we get the flickering of the screen going on and off and horizontal lines that flicker across it. after turning the TV off and on a few times it seems to go away (or after it warms up)
i know know if i should order another bulb and ballast and spend the money for it to happen again or if it could be something else
let me know if you find a solution.. carolynspranger@gmail.com
Sep 07, 2010 | Samsung HLP5085W 50" Rear Projection...
I have a Rheem Criterion II Gas Furnace that has been acting up the last couple of days. It is model #RGPH-12EARJR. It will cycle on, ignite the pilot, 4 burners light and stay lit from 5-10 seconds then...
Turn off the power to furnace.
on the last burner to light there is a small metal rod in front of the burner. This is a safety called the flame sensor. It is dirty. Unscrew it from the bar ( 1 Screw) unplug the connector wire from it and clean it with steel wool. it will be kind of burnt. Plut back in place and turn on the furnace to cycle.
Apr 04, 2010 | Heating & Cooling
Tv does not stay on
If you have a rear projection, it is the bulb. Ypou need to replace it.
Jul 24, 2009 | Mitsubishi WS-55859 55" Rear Projection...
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
RCA HD50LPW62AYX2 WILL NOT STAY ON
My HD50LPW62AYX2 RCA TV sometimes reverses the blue and reds. The peoples faces are blue, especially the lips.
Sometimes turning the TV off and then back on again fixes the problem. At other times this correction is good for only a second or two.
Do you have an English owner's manual available on line or otherwise available?
Nov 21, 2007 | Televison & Video
Panasonic PT-50LCX63 50" Rear Projection Television Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
