Question about Baby Lock Evolve
The tube in the back looper must be blocked as I can not get the air to push the thread through. How do I unblock it
Are you sure you're not trying to thread through the 'chain' port? I've done this a few times, almost pulling my hair out trying to figure out why the thread wouldn't go through. Then realized this simple mistake on my part.
Posted on Mar 02, 2011
Serger - my needles break, never happenned before, and over travels on left upper looper
Make sure, Joe, that your needles are pushed up into needle bar shaft a's high a's they will go. Although same length, the left needle will appear higher than the one on right side when properly seated and tighten clamp screw securely. Check Lower Looper for proper threading--thread delivery eye of lower looper to far left "hidden" from sight. Use looper tweezers and it helps threading it. The thread then gets pulled to right side and goes front to back of that hole in front of you on lower looper. Follow threading guide on the cover door to right of your serger. Hope this helps. Jimmy
Apr 04, 2012 | Sewing Machines
I want to use the 2 thread rolled edge. I put the 2 thread converter on the upper looper. When I thread the lower looper, where does the thread go - ie does it go over the 2 thread converter on the upper...
Thread the lower looper like normal, and you needle. When the upper looper comes up it will push up the lower thread and then you can put it under the pressure foot torward the back and start to serge.
Apr 19, 2011 | Elna 945 Computerized Sewing Machine
Jet air not working on the evolution serger by babyloc can anyone
HI
Have you tried to use the wire to pull some floss type thread through the loopers ( I often use a cleaning fluid on the floss thread to clean out the inside the looper tubes.
If this fails to help, likely a professional change of the loopers should be considered
If you have further questions, contact me at sewaway@shaw.ca
Wayne Buss
Apr 19, 2010 | Sewing Machines
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Lower looper thread blocked partway into threading mechanism and wiln not move up into serging position
You should have gotten,wit your machine, a wire that is intended for threading thicker threads in the loopers. Try engaging the tubular system and then feed this through the looper with a thread like DMC pearl cotton attached. This might clean out the pathway. I would also make sure I vacummed out the machine really well. You may need to have your machine serviced, if you can't get it out.
Feb 07, 2010 | Baby Lock Evolve
When I try to thread the right looper, I cant get it to go down the hole. the one on the left goes in just fine. I have always pushed the thread down just so far, then push the button for the air to push...
Hi, I have a Babylock Imagine, but had exactly the same problem so found your question when looking around. After tinkering for a bit, I figured out that there was a thread stuck somewhere between the air threading hole and the lower looper eye, and it was causing the air to blow backwards. I pulled the thread out and everything started working correctly. Looks like the Evolve is set up similarly--pull down the front cover, then pull the needle cover down and see if you see anything caught in there.
Aug 02, 2009 | Baby Lock Evolve
Automatic threader does not take the thread. I
Open the front cover and raise presser foot to release all threads. Depress the machine lock button firmly with your left index finger. At the same time manually rotate the machine hand wheel slowly forward until he button "snaps" into the locked position and the lock button release lever moves to the far left.
Apr 12, 2009 | Baby Lock Imagine
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Lower looper thread jammed in tube
my husband took a very thin stainless steel wire and very carefully put it through th eloop and the thread came out the eother end and and I could see how bunched up it was inside.
I hope this will help others
Apr 28, 2008 | Baby Lock Evolve
Unable to thread lower looper on Babylock Eclipse BLE1SX
On rare occasions lint can clog the yubes on these sergers. One of the first things I do is thread the wire through in the opposite direction. It will sometimes push the blockage out. The other option is to use an air compressor and again blow the lint out from the opposite side. If this does not work take it to a service man.
Dec 18, 2007 | Baby Lock Eclipse Serger
Sewing Machines Logo
106 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
