Question about Hitachi NR90GR Cordless Round Head Gas Framing Nailer
1 month old gun, wires that connect to the fan got pinched and severed after i cleaned it and shot a couple hundred more nailes, I resoldered wires but now no fan , gun wont fire...fresh battery and fuel
  • 6 more comments
  • pefcmf Dec 31, 2010
    how far down the fan wires is the resistor...and fyi.. the wires i soldered were on the trigger side so thats 7-8 inches long, not the 2 inch wires going into the fan itself
    where is the board.. ij looking at a parts schematic and dont seeit listed...and is this something i can purchase and replace myself??
    ah..i do see that on the schematic...ill check fan power then first
    ok..wont be until monday unfortunately
  • pefcmf Jan 04, 2011
    Ok so I tapped into the fan wires on the female plug side that was not the side i soldered , took out the battery and then linked the leads to the battery and the fan powered on.
    I then conected to male side of the plug where the solder is and touched the actual solders I made,, plugged it in and the fan powered. I then tapped before the solders and the fan powered. SO I am assuming thern the controller is fried?
    clarify your sentance please...
    It the nose trigger making when you push it down???
    yes I know about the nose...but did not know of the switch in the nose..ill check that out asap...if I need he controller do you know off hand a good resource...or do I ust google the part number hitachi 885595
  • pefcmf Jan 05, 2011
    thaks for the time..ordering the controller..hope it solves it!!
  • Hitachi Master
  • 43,501 Answers
Check for power to the fan... it should be 12vdc or whatever battery you have there...
either the wires did not get hooked up or soldered right or the short blew the board or a fuse somewhere...
heatman101
Posted on Dec 31, 2010
  • 3 more comments
  • D. Floyd Kolb
    D. Floyd Kolb Dec 31, 2010
    I think the technical name is "controller" ....
    But before I would do anything I would be checking for power to the fan...
  • D. Floyd Kolb
    let me know how you make out...
  • D. Floyd Kolb
    no problem...
  • D. Floyd Kolb
    D. Floyd Kolb Jan 04, 2011
    Obviously you have proven that the fan works... so the problem is in that the fan is not being energized... the controller seems to be the logical problem...is there anything else that you can see that would stop the flow??? It the nose trigger making when you push it down???
    That is the only other thing I can think of... but yes I figure you fried the control when the wires shorted...
  • D. Floyd Kolb
    The nose of the gun needs to be pushed down before the gun can fire or there would be power to the fan... that is probably tied to the controller, but I'm not exactly sure how it is on that gun...I think there should be a switch that closes when the nose is pushed in...check that switch out also...
  • 10,319 Answers
If the time to solder the wires took too long the resistor may have gotton a little too hot and finally shorted out leaving the circuit open causing your problem. I would see if a tool rental shop will repair it for you. they are the best reasonable way of saving money repairing tools of this nature
Posted on Dec 30, 2010
  • frank thomas wilson
    frank thomas wilson Dec 31, 2010
    one month old? take it back for exchange instead of fighting with it if you did not change the exteriors cosmetics with the exception of common waer
My paslode IM350 nail gun wont spark but wen i remove the fan cover and unplug the fan it sparks nothing is loose and everything is connected but cant see what the problem is can anyone help thanks
With gun assembled but gas cell REMOVED look at LED on handle, with battery fitted LED will flash. Now press it against work piece, LED will stay lit whilst still watching LED press trigger. LED should blink off (it may blink red) this indicates that the spark unit has sent the spark. If this works it sounds like either the spark lead has been damaged and spark could be shorting across back of cylinder head or you actually have a gas problem. Check cylinder head O ring, use by date on bottom of gas cell. Depending on age of gun it may have another O ring on the sleeve (pre 2006). Check sleeve is clean do not add oil to working parts (except a smear when cleaning sleeve and around O rings when reassembling gun)
Mar 21, 2014 | Air Tools & Compressors
I have a new im65a pasloade nail gun that has only fired a couple of hundred nails and after standing for about 16 months the gun does not seem to be firing the fan comes on the green light flash the
your gas has expired , look at bottom of canister check the date. buy new gas also make sure cap on gas canister is down all the way till it snapps new gas doesnt come with cap down all the way
Apr 24, 2012 | Senco Air Tools & Compressors
Just cleaned gun, shot about 300 nails, and wont shoot nails anymore, all within 2hrs.
wow 300 nails in an hour for this gun is alot. I am a professional framer and would not recomend this gun for that kind of use. The only time I use the pasload is when I have a small punch list. Not sure how old your gun is or how long you have been using it under that much of a load, but my guess is you may have burnt it up. The only real answer for these guns is to take them to a qulified repair person.
Mar 03, 2010 | RTO PasLode 900420 Impulse Framing Nailer
SENCO COIL ROOFING GUN DOESNT ADVANCE NAILS EVERY THRID OR FOURTH NAIL DOESNT ADVANCE
Clean the track and piston by removing nail tray (there are a couple of allen screws)and removing the gunk from the nail tape and if you have been shooting something glued that to. Remove head assembly and thoroughly clean and oil that also. that should fix you right up I have a couple of these guns and that is typical.
If that is no the problem rebuild the gun it is worth it as they are a great air gun
Hope this helped
Dec 15, 2009 | Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2...
Gun does not fire every time
make sure the safety is being pushed in all the way
it will not fire unless the safety is fully engaged
Dec 12, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse cordless nail gun,doesn't pull the piston back far enough to catch the next nail, so when I fire it no nail is picked up by the firing pin. batteries are good(new), cylinder is new, any...
This is an easy fix luckily usually it means that the chamber is dirty and all you have to do is open the top front of the gun so that you can see the piston then take a q-tip and clean the area really well sometimes it requires a degreaser and then when you think that you have it clean make sure to lubricate the chamber really well with the paslode lubricant that came with the gun or they sell it right next to where you get the nails. Then the gun should work fine with no problem if this does not work then this means that the piston might be bent and that could turn into a big problem but is still fixable just harder.
Hope that this works for you
Nov 25, 2009 | Tools & Hardware - Others
IM250 Paslode straight brad nailer, fan wont shut off
My paselode was doing the same thing, and I followed all of the cleaning instructions, but the problem continued.
If it was left alone for a minute, it would fire again, so I removed the cover over the trigger assy, and checked the spark plug wire connection. The trigger came out, and during reassembly, I noticed that the electrical switch was hanging, and slowly pushing back out.
I cleaned and lightly spray/oiled the switch pin, and voila.........works like a charm.
Jul 26, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Nailgun firing pin not connecting with nail
  • you need to make sure the guns is clean and oiled
  • make sure you are using the right kind of nails
  • some perfer the ones connected my wire and some the ones connected my paper.
Not knowing what kind of gun you have that is the best I can do..
Apr 15, 2009 | Tools & Hardware - Others
A Bostitch F28WW that spontaneously fires a nail when coupling the air hose to the gun. The gun is 12 years old. Whats the fix required.
When was the last time this tool was serviced? Bostitch makes an Oring kit for this part #N890RK I could not find the price. I would start by looking at the safety to make sure that is moves freely and is not bent. Then I would think about putting new rubber in this tool. First go to Stanleybostitch and navigate into tools and then support to look at a breakdown for this one. It is not that difficult to rebuild, if you do make sure that you put lube on the new orings and take your time rebuilding to ensure that you dont pinch one of the new rings. Hope this helps
Jan 15, 2009 | Stanley Staple/Nail Gun Elec
Hitachi NR90GR Cordless Round Head Gas Framing Nailer Logo
139 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
