Question about AEG U3100-4 Electric Double Oven
Hi main bottom oven will not heat, fan moves, light works but no heat. Is this something I can fix myself easily? Thanks Mrs edel Relph
  • AEG Master
  • 3,463 Answers
You need to replace the oven element located at the rear of the oven compartment behind a removeable cover.
Posted on Feb 19, 2011
Baumatic OSF60OVEN 60cm fan oven. Grill works, fan works, light works but oven is not heating up. Is it likely to be something I can fix myself?
You possibly have a blown heating coil, the most likely one is in the main oven, as this is the one that's used the most sometimes you can tell as the element shows signs of blowing other time it doesn't the only way to check this is to remove it and put a test lead to either end on connection clips to see if it's dead also on the element it's self to see if it's gone to earth, but must be removed or disconnected on the end terminals so you don't get a false reading. if you are a handy type person there is no reason wye you can't undertake this work just make sure the electricity is disconnected from the oven prior to any work being undertaken Good luck
Mar 02, 2015 | Baumatic Ovens
Hello The light, the grill, top cooling fan and main circulation fan all work but the oven doesn't heat up at all. So I assume it's the main element - but isn't there more than one main element...
Yes it does mean that there is a base element, but more likely to be fan element, possibly base element may require replacing as well.
Oct 27, 2010 | Ovens
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
May 23, 2010 | AEG U3100-4 Electric Double Oven
Smeg fan assisted oven not heating up , top oven works fine but main bottom oven doesnt heat up at all but fan working fine many thanks
So long as fan is working o/k, then all you need to do is replace the oven element at rear of oven
Please rate my solution.
Thanks
Nov 10, 2009 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Zanussi zuf270x main oven not getting hot
I've just mended this myself and it took about 15 mins:-)
It's more than likely the heating element, you can get one off the internet for about £20 if you go for the electrolux replacement.
Open oven door and remove the trays, undo the four small screws on the back wall inside - not sure if you have to, but I turned the power off at this point. Better safe than not! Turn this around to the right wall as it won't come right out due to the bit of wire on the right (temp sensor maybe?).
If you've already got the new element you can guess what happens next; take out the 3 small screws holding in the element and gently pull towards you. It's attached to two wires poking out of two holes - take the bottom one off first as it seemed to have less tendency to fall back in the hole (I reckon that could be a real pain to get back).
Hold the wire still and wiggle the old element to remove as you will have less chance of damaging the wire that way. Reconnect the wires to the new element and pop it back together again.
Job done and after a year of waiting we now have double the oven space!
Jul 29, 2009 | Zanussi ZHQ575 Electric Double Oven
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Aug 15, 2007 | Neff U1721 Double circotherm Electric Oven
AEG U3100-4 Electric Double Oven Logo
335 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
