Question about Casio Cassiopeia BE-300 Pocket PC
Loses charge my pda is fully charged and when i disconnect it from the charger it stops working and shuts off after 2-3 minutes. Help
  • Debbuy Nov 27, 2008
    When I recharge my pda it stays on for a second or two and then issues a warning that I need to change my settings and then shuts off. Help
  • 4 Answers
The battery os more than likely dead. You can get factory batteries off Ebay or there are other replacement ones available. Go to www.be300.org You should find information on alternative batteries there.
Posted on Dec 02, 2008
Tip
Keep NiMh batteries fully charged?
NiMh batteries lose charge quickly after a 15 minute charge. Keep the batteries in the charger so that trickle charge keeps the float voltage up to maintain fully charged state until you have to use the batteries.
on Aug 14, 2010 | Cameras
Tip
Tips on how to make the cellphone batteries last for long
1. Do not charge the cell phone, hand held devices or PDA if the device is not running out of charge.
2. Make sure the phone is turned off while charging.
3. Do not disconnect the charger if the phone is not fully charged.
Doing these steps would make the batteries last for long.
Have a good day!
on Dec 01, 2009 | Cell Phones
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
I fully charged my flea, and now it won't stop flashing
I think I found a solution.
My flea would keep blinking the ready light after disconnecting from the USB charger. I ran it on the low setting for a few minutes and then turned it off. It stopped. Maybe you need to take the "top" off the charge. We'll see if it works.
Feb 09, 2010 | Blackburn Flea Front HL Bicycle Headlight
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 | Cell Phones
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Zire72's on the fritz!
Plug the ac wall adapter to charge the PDA and leave it there.
When the PDA exhausted the battery charge, it needs minimum 30 minutes to charge to the minimum level to have the PDA powering on.
Once it powers on, leave it charging the battery until is fully charged (3-4 hours).
Best regards,
Sep 02, 2008 | Palm Zire 72 Special Edition Handheld
Stops while talking
Hi folks with aging JAMS. My JAM is still dying (complete shutoff) using phone. I wish it would just lose the phone signal but my unit shuts off completely during phone calls. I can have 80% charge. I spoke with a friend that mentioned on his cell phone (different manufacturer) that although his battery will show a full charge or less, the time it takes for the charge to go down is ridiculously fast once the battery is old. He watches his phone lose a charge in under an hour though it charges to full.
I wish IMATE would make some formal post regarding when to get a new battery and what symptoms are possible. I'm a bit hesitant to invest in batterys if the issue is hardware. I use the unit alot--as a PDA, a phone, etc. It gets jostled about so maybe something is lose inside, though I doubt it.
I purchased a cheap phone charger so in the car I'm recharging and at work I just keep a cheap USB to plug charger. I reserve the phone when I'm out. This is not really optimal for cell phone use but it's a behavioral fix. I figure I should be looking at a new device (despite high prices) soon.
I did a full discharge/charge cycle or two or three but only noted short term benefit. At some point the quirky behavior returned and off went the PDA cell with the 80% charge. I see dots of us around the net. Again my Jam is probably 3 years old this March.
Oct 28, 2007 | i-mate JAM Pocket PC
PDA would not turn on...
try to charge it for longer time, then try to turn it on, i'm not sure that its gonna work.
Jul 24, 2007 | Dell Axim X51v Pocket PC
Casio Cassiopeia BE-300 Pocket PC Logo
93 people viewed this question
Top Casio Computers & Internet Experts
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
