Question about Brother Office Equipment & Supplies
Sadly my brother AX-100 is stck at the left hand side of the carriage. I cannot do anything. The machine tries to get itself warmed up but then a bell rings repeatedly. I canno move the daisywheel housing to the centre; nor can I insert the daisywheel or ribbon housing ( which were removed for transit ) as the carriage has moved to a fixed position the left.
  • 86 Answers
With the machine turned OFF, you can move the carrier to the right by hand fairly easily - DO NOT TRY TO FORCE IT- if it doesn't move, look inside the machine to see if some forein object is stopping it.
If the printwheel is not in the machine, it would normally go to the left, stop and start beeping. Its not really necessary to remove the ribbon and printwheel for transport, but it is a good idea to put something inside the machine to stop the carrier from slamming back and forth as it's moved.
Posted on Jan 06, 2011
How does the print head on a Brother ML-100 sense when it has reached the left hand side after a carriage return?
when the print head reaches the left side it touches a switch to cause it to inter the setup for the print wheel and ribbon mechanism
Dec 06, 2014 | Brother ML-100 Typewriter
Carriage return stuck on left side when powering on
The first thing to try is to lubricate the silver rail that the carriage rides on. A few drops of a light oil ( sewing machine oil ) may take care of the problem. Turn machine off, apply oil and move carriage by hand back and forth. Turn back on and see if this took care of it.
May 14, 2013 | IBM Wheelwriter 6 Typewriter
Carriage will not go past right hand margin on Brother Ax 430 typewriter tried following user guide but still cant move carriage - it is halfway across paper
Have you tried to Unplug and again plug in after few minutes. If not, give it a shot right now.
Do you see any error message on that?
Is correction tape working properly? You could also try to pull up and again put it back to see if that would improve the situation.In order to do that it would involve taking the case off, removing the rails, the cable and the carriage drive and putting it in the other machine. Novel idea but not something easy.
Let me know the update, once done.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 23, 2009 | Office Equipment & Supplies
Brother GX 8250: my problem is with the carriage.
Brother GX8250 typewriter; my problem is with the carriage. The return key returns the carriage to the original left-side position, but fails to advance to the next line.
Sep 08, 2009 | Brother Office Equipment & Supplies
Was the carriage return ever on the right?
I have worked on typewriters fo 20+ years.
The only typ's I know of that had the return on the right hand side are all the manual typ's
Feb 19, 2009 | Brother ML-500 Typewriter
HP PSC2355 all-in- one printer Carriage jam
Try to move the carriage manually..it works most of the time....if still does not work...replace the printer.
Nov 25, 2008 | HP Office Equipment & Supplies
Brother AX430
Check to see if you are in proportional spacing, if so move switch to 10 or 12
DickyO
Feb 13, 2008 | Brother EM-430 Typewriter
No Typing, but Powers Up, brother ax-25
open your typewriter and muve prinre left-rigt, you have a prnters jam or power suply module is not ok too low dc voltage
Jan 25, 2008 | Office Equipment & Supplies
Sharp ux b700
check carriage home postion sensor(often in your left hand near left end of the machine-check for a broken connector and reconnect it-check for droped object or dirty in the sensor.
Jan 21, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
141 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
