When hooked up to an LCD TV DVD picture comes out black and white
    Genius:
  • 1,456 Answers
Helllo
Your have probably put your dvd player in the wrong mode,your Dvd which you are trying to play might be NTSC while the dvd might be in PAL or vice versa please check your mode settings to be sure or better still you should put your dvd in the auto mode system which automatically selects the right mode for the dvd you are trying to play
Please also check that your AV cord is properly inserted and they are all in the right ports
Posted on Dec 30, 2010
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
How do i get black n white to color
Where are the pictures coming from?
Off-air, cable, DVD, VTR, computer, etc?
Feb 13, 2015 | LG 32LD450 32 In. LCD HDTV
I hooked up my ps3 and the picture comes in and its in black and white?
Are you using component input on your TV, RGB? or Single RCA?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Sep 25, 2014 | RCA L32HD31 32 in. LCD HDTV
I'M TRYING TO HOOK UP MY INSIGNIA 42'' 1080P FLAT-PANEL LCD HDTV TO OUR DVD PLAYER USING THE COMPONENTS (RED, BLUE, GREEN, RED & WHITE CABLES) PROVIDED AND THE PICTURE IS IN BLACK & WHITE....
The three picture cords (red/blue/green) often are a little larger around than the sound cords (red/white). If they are they same size, they are often grouped separate by picture and sound. Double check to verify if you have the "red" cords correct. Good luck.
Jan 20, 2011 | Insignia 42" LCD Flat-Panel HDTV
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
When I hook it up to the TV and set it up as component 1 I only get black and white and no colour.
Are you using component cables (Y=green, Pb=blue, Pr=red, white, and red) ? If so try changing the component cables. If the picture is still coming in in black and white try another device besides that DVD player that has a component output. If a second device is coming in in black and white with a new component cable then it is the television.
Jul 27, 2010 | Daewoo DVDS151 DVD Player
I have the tv only hooked up to a dvd player, picture only comes in black and white, i am hooked up with componant cable and audio cables
Check to make suer you ae not on progressive scan as that will display the images in a black and white format. Also check your system settings and make sure they are correct, NTSC, PAL, SECAM, etc. i hope this helps. Good Luck.
Nov 23, 2009 | Syntax Olevia 226T 26 in. LCD Television
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
DVD hookup to LCD monitor only appears in black and white!
I have a RCA flat screen television and my dvd player when hooked up is in black and white. How would i fix this and if so plz be more specific then these other people.
Jan 02, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Magnavox mwd7006 dvd player hookup
if you are useing componet output and the pic is black and white you have them hooked up in the wrong order
The Cableguy
Oct 17, 2007 | Philips Magnavox MWD7006 DVD Player
Televison & Video Logo
Top Televison & Video Experts
