Assembly of model # SNA-950TG . The instrucrion are not any good for all the little stuff
2 Suggested Answers
  • 24 Answers
SOURCE: we have a ge side by side and the refrigerator is
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Posted on Jul 30, 2009
Need instructions on how to use tools AST #u2 /#2066 for a vw Diesel motor
The make and model of the vehicle are also necessary
Nov 24, 2014 | Cars & Trucks
SNA-950GT assembly instructions
Sorry do not know this type of printer.
Dec 21, 2011 | Office Equipment & Supplies
Windshield wipers don't work. Not the fuse. Also my blinkers don't work. Had to take out fuse. If let in driver side blinker stays on. Arm does not do anything
Start with the easy stuff. Since you've already ruled out fuses, both issues sound like bad relays. The blinker relay is usually in the fuse panel and cheap to replace.
The wiper relay if I'm not mistaken is in the switch assembly on the steering column. This is a little more expensive because you have to replace the whole switch assembly.
Mar 09, 2011 | 1998 Mitsubishi Mirage
My cooking creations kitchen didn`t come with an assembly instruction manual
Here is the link to download assembly instructions, though I did not see "cooking creations" listed, you may try entering the exact model number:
http://www.littletikes.com/consumerservice/little-tikes-assembly-instructions.aspx
Note, that Little Tikes does not post all assembly directions- some products do not have them online. However, if you contact them via this form, they can send them to you:
http://www.littletikes.com/consumerservice/Contact-Us.aspx
Just select "Product Help" from the subject field. Good luck to you, hope this helps!
Jan 09, 2011 | Little Tikes Toys
I need instructions on how to put a new clutch in a 1988 toyota 4x4 pick-up.
bit of a job but you can do it remove driveshaft
remove cross bar (most models) disconnect the transfer case disconect the slave cylinder and all the lines going to the cooler support the motor take the trany bolts loose and pull the transmission out
remember that they are heavy ( replace the clutch
use the alinment tool reinstall the new clutch pressure plate and throwout bearing assembly
reinstall the trans /transfer case and drives shafts
crossbar and all the little stuff cooling lines etc
slave cylinder etc good luck
Mar 05, 2010 | Toyota Pickup Cars & Trucks
How to set my seiko sna663 divers watch
Hello
Ok, i found a link where you cand download the manual for your seiko SNA series.
Just click on the link below and you will be directed to the page where you can download the manual.
http://safemanuals.com/user-guide-instructions-owner-manual/SEIKO/SNA%20SERIES-_E
Kind regards
Andrea
Dec 06, 2009 | Bulova Watch
How do I fit a new keyboard to Dell D420 laptop?
You cant just fit any ole keyboard to any laptop. I suggest contacting Dell, and look for replacement parts. Most of Dells' stuff is propietary
http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&cs=19&l=en&s=dhs&redirect=1
Dec 03, 2009 | Dell Latitude D420 Keyboard
Web camera with USB, it is Dell but i cannot find its model
I never heard of dell manufacturing Web Cams. I know that they have some built into there monitors...The following link should be of good use!..
http://accessories.us.dell.com/sna/category.aspx?c=us&category_id=6355&cs=04&l=en&s=bsd
May 13, 2009 | Computers & Internet
I need operation instrucrions for my Toshiba Tecra 8100 pc..
Hey silly.... it's located behind the left speaker. There could be a little sliding safety door that's blocking it...
Jun 25, 2008 | Toshiba Tecra 8100 Notebook
Whirlpool GU1500 chopper assembly cover
I had the same problem. Grabbing the little tab and yanking does not seem like the best idea, as it has a groove that fits around the chopper screen, and another lip that fits tightly against the motor housing. There is also a hook at the bottom of the tab that helps hold the cover in place. If you are too rough you could damage stuff. I found if I used a thin lever (screwdriver) on the screw flange side, and worked tthe tab gently with a needlenose, it came free without too much trouble.
Mar 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Televison & Video Logo
492 people viewed this question
Top Televison & Video Experts
Electro Med Services...
