My R1800 will start to print. It will start to feed the piece of paper and the print head swings all the way left to begin the print and then it loses power. What could be causing this?
  • mego73 Dec 30, 2010
    I will check this but the odds might be against that because when I restart the printer, it usually goes into a cleaning cycle and the head does a few test swings and it does not lose power at that point. It seems to only happens during the start of the print. I think the test swings do not advance the head all the way to the left but it goes at least 3/4 to the left. The problem seems to only trigger when the head swings all the way to the left so it would have to be a rather picky short.
  • mego73 Jan 05, 2011
    The ribbon cables seem to be in great shape and all the functions work, except for printing. I am wondering what sensors are involved at the start of a print and if I can access/clean them.
  • 591 Answers
Your print head probably cause a short circuit when comletely to the left, check the flat plastic cable that is connected to the print head for ware and exposed wires that can touch any parts of the metal frame.
Posted on Dec 30, 2010
  • Tommy
    Tommy Jan 05, 2011
    when you say it LOSES POWER do you mean it shuts off completely or it just stops with LED's still on? if that is the case try to notice at that point if they (or it) flashes a code than you can look it up on the Epson web site
    Cheers!
    It actually loses power making it necessary to cycle the power switch to restore power. The printer will swing the head to the left when it starts to print and when it does the power (and the green power LED) goes out every time at the same point.
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800: printing 13x19" velvet paper. hand feeding into rear of printer. keeps saying eror, or paper jam or ... then finally just spits the paper through and out.
why print velvet paper? the problem is the velvet would be too thick and it would jam the print heads because when they run over the paper it would pull the velvet and it would get jammed i don`t think you should print velvet
May 16, 2010 | Epson Stylus Photo R1800 InkJet Printer
My epson R1800 printer sometimes ejects the paper to soon
I solved this problem by wedging a piece of cardboard in the slot next to the on-off switch. This stop the printer from cycling during the printing due to vibrations.
Feb 17, 2010 | Epson Stylus Photo R1800 InkJet Printer
A piece of paper got stuck in the printer. I pulled it out,but now the print of the words is flawed. How do I clean the printer heads?
If the paper tore, piece it together and make sure there is no paper bits left stuck in the paper feed-path.
Failing that, remove the cartridges and then remove the print head. Wash it under warm water. Dry with paper towel or toilet paper by blotting it gently. Then run a nozzle check and a nozzle clean.
Dec 07, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
Hope this helps
nickerjo,
leaningpalmstudio.com
Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
Paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
May 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
R1800 printer problem
I fixed the problem, the PW and Ink Mark sensors needed cleaning. I was able to access and remove both sensors after removing the printer housing, and moving the print head to the far left. There's enough space to unscrew the cover for the sensors, and unplug them with needle nose pliers and a couple fingers, clean them both, dry them, re-install, etc.. all is well now after some re-alignment procedures with the epson factory service program.
Oct 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
23 people viewed this question
jasbo
jasbo
