Question about Sears Exercise & Fitness
When Iam walking on my treadmill it will change to a very fast speed
  • Sears Master
  • 6,694 Answers
check the speed sensor in ur tread mill. may be it has become dirty. clean it and refix it. u can find out the speed sensor near the motor pulley.
ok
Posted on Dec 31, 2010
2 Suggested Answers
SOURCE: Lowest speed of elite personal trainer tm500 too fast.
It requires a drive belt adjustment. Gain access to the motor and belt (Disconnect from power supply first!) and reajust belt tension.
email me on mickey67@tpg.com.au if you need help. It's not too difficult a job.
Posted on Jul 26, 2010
Treadmill speed is going fast when I have it at 2.5
Your variable resistor (speed adjustment switch) is going out
Mar 23, 2016 | Sole Fitness F63 Treadmill
Speed changes on it own
speed controller is malfunctioning
Dec 11, 2013 | Weslo Epic 10pi Rear Roller For Model...
Would like to know the top speed for the reebok rt1000
just bought one second-hand from someone and set it up in out flat. Had a liitle play and cranked it up to 9.5mph which was too fast for me so at least that!
Mar 15, 2013 | Reebok Rt1000 Treadmill Walking Belt
Nordictrak T5.7 treadmill squeaks while walking
please LUBE the deck belt and roller bearing very important
if the problem persist after you did. Is time to change the deck belt.
God bless you
Jan 08, 2013 | Exercise & Fitness
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
Jun 26, 2009 | Exercise & Fitness
Treadmill may be slipping
Depending if this is a new issue or old, It could be a couple of issues. Check the belts for slipping. Proper tension on walking belt (check your manual) or drive belt -remove the cover and you might be able to see if the belt is slipping or it could be a load issue (electronics not sensing added load fast enough). My bet is belt tension. Also Lubricate,lubricate,lubricate
www.twincityrepair.com
Feb 28, 2009 | Reebok Exercise & Fitness
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
143 people viewed this question
Top Sears Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Sears Exercise and Fitnes Expert? Answer questions, earn points and help others
