Question about Dryers
GE dryer squeaking only when it turns with clothes inside. Is has been sprayed with white lithium grease.
  • 1,543 Answers
Replace the rear drum bearing. WE3X75
Posted on Dec 30, 2010
Have squeak coming near front axle on passenger side
on what that would really help, check brakes
Sep 30, 2014 | Cars & Trucks
Fan squeaking
Try spraying white lithium grease all around the shaded pole motor axle while the motor is running making sure to have it get into the bearings
Oct 15, 2013 | Bionaire Dehumidifiers
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
Squeaky Door....embarrasing!
1: White Lithium Grease
2: Silicone Grease
Either will work just as well, though lithium may be easier to find at the local auto-parts store...and a bit cheaper.
* They silicone comes in a spray which makes it easier to get to the hinges.
In a pinch, a can of Liquid Wrench will cure the noise, but it doesn't offer the long-term benefits of grease.
** There are 2 sets of hinges, upper and lower...and be sure to get the rollers on the guide arms.
***Don't forget to VOTE for the guys who take an interest in helping!
Jun 19, 2010 | 2000 Volkswagen Jetta TDI
Loud squeaking when you first turn on the dryer, it usually calms down after the dryer has gotten warm and the squeak is not so loud. Also tags from clothes are getting caught around the inside rim of the...
The problem is your bearing is nearing the end of its life. I just had mine apart and put a touch of axle grease on the drum main bearing, I also put a touch of this on the idler roller shaft (avoid getting any on the belt). Do not use petroleum jelly (Vaseline product) as it will turn into a liquid at the temperature the dryer runs at .
Dwight
Mar 31, 2010 | GE DBXR463EDWW Electric Dryer
High pitch squeak and removal of cloth support
try some felt from fabric store in same place
May 06, 2009 | Dryers
I have an Amana gas dryer that is squeaking. Does something need to be lubricated? If so can I do this myself?
Good Afternoon,
Lubricating would be just a temporary fix. You need to replace the drum rollers. If you think you can do it yourself I'll try to walk you through it. Once the rollers are worn they start squeaking and squealing at a very high pitch. This happens because the roller bushing spinning on the shaft has dried out from the heat. The weight of the clothes in the dryer plus the drum itself rests totally upon these rollers. If you decide to install new rollers clean up the shaft with lite emery cloth then wipe clean. Next apply "High Heat" Lithium Grease to the shaft and inside the new roller bushing, they will last 2 to 3 times longer. Let me know if you need guidance if you attempt to change the rollers yourself.
Have a great day!
Mar 26, 2009 | Amana ALG331RAW Gas Dryer
Steering wheel squeaks when turning 2-3 times in same direction
where the sterring shaft meets the firewall on inside of the car there is a rubber gromet apply white lithium grease and it should stop the squeak
Jul 30, 2008 | 2007 Toyota Camry
GE Spacemaker washer/dryer
If you can get it apart, you should be able to fix it yourself. This is a tricky task though (I've seen customers spend hours just trying to change a belt, which you'll have to remove), so you may want to pay the money and have someone come out.
It is hard to say without hearing the noise for myself, but my best educated guess would be that the dryer drum bearing needs to be lubricated. You should lubricate it with white lithium grease, about 1.5 ounces of it.
In order to do this, you will have to take the dryer front off, remove the belt from underneath the drum and then remove the drum. You will see a bearing on the backside of the drum (looks like a post with a ball on it). You will see where that inserts on the back wall of the dryer. You should put the grease in the insertion point, then put the dryer back together again.
Mar 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryer
nothing in the dryer i.e.crayon left in pocket?? there is no black grease used in the unit only White lithium style.. I dont think it came from the inside of the mach ...Best bet is to clean the tub out mild soap and a damp cloth it should go away. if not the peice maybe stuck in the baffles manually spin the drum do you hear anything rattling around?? Let me know
Jan 26, 2008 | Dryers
Dryers Logo
82 people viewed this question
Top Dryers Experts
