ArcServe Backup error codes E4109 Unable to add session record. (EC=Error Code = 3) W3502 Unable to add session to database (EC=3)
  • 115 Answers
SOURCE: backup
There may be a bad sector in your harddisk or the virus .First run and type "chkdsk" without quotes from the Run (start menu, goto run). Check the all disk of the harddisk that you connect to your system. Other thing install the antivirus and update it scan our system. these are possible thing that you can do. try it and inform to fixya.com
Posted on May 07, 2008
manishbhatia
  • 42 Answers
SOURCE: A window appears with the
It appears to be a scheduled backup task not being completed.
You can disable the task by going to the backup software and removing the backup schedule.
I can't tell you the exact procedure since i don't know anything about your system.
Posted on Aug 02, 2008
Nerdy_geek
  • 94 Answers
SOURCE: When trying to do a
the error code refers to unreadable stack on the program possible a corrupted file system.
to recover your file i would advice this recovery program its kinda useful for recovering files.
www.grc.com/spinrite.htm
Posted on Sep 18, 2008
syedmujahed
  • 158 Answers
SOURCE: windowes error code ox80040707,which usually
download the ccleaner and run the registry cleaner
Posted on Sep 26, 2008
SOURCE: SonicStage error message upon opening software
had same problem, but it's easy to solve. When you use vista and sonicstage 4.3 (vista version)
the only thing you have to do is to go to the propertiesscreen en turn off the compatabilitymodus with xp en it will run fine.
Posted on Sep 28, 2008
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
Cant open quickbooks , message pops up error code 8000ffff
If your problem did not solve till now, i would suggest you third party tool which will repair your corrupt QuickBooks file and save your data in working condition.
http://www.recoverfilesdata.com/quickbooks-file-recovery.html
Free to Try Version is Available
Aug 10, 2012 | Intuit QuickBooks Pro 2008: Windows
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
When I trying to open the archive files, error "RRV Bucket is corrupted" is displayed. I am unable to solve this problem. can you please provide a solution. I understand data can be retrieved ,...
If this error occurs in a case where Shared Mail is being used, then first refer to the documents titled "'RRV Buffer Overflow' Error Message While Attempting to View a Mail Document" (#1093390) and "Using the OBJECT COLLECT Server Task to Manage Shared Mail Databases" (#1088860).
If the database is not in R5 format (ODS 41), then from a Domino 4.x server run Compact -M on the database. On a Domino 5.x server simply run Compact on the database. If updating the ODS to 41 does not resolve the issue, refer to the document titled "Database Has Grown too Large; Use File New Replica...' Error Occurs When Opening Local Database" (#1102305).
If none of the above resolves the issue, then where possible, a new replica should be made. If a replica is not available, restore the database from a backup, if one exists.
Supporting Information:
Corruption can be caused by many things, but a possible cause for the error in this case was that a third-party application had altered the physical location of the database on the hard disk, resulting in the Record Relocation Vector table being incorrect and the information not being located. This has been reported to happen with customers using a disk defragment utility while Compact is running.
May 28, 2011 | Computers & Internet
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Corrupt MYOB data file
Our MYOB 14 .dat file is crashing. We suspect a corrupt entry in the database. The file will open but as soon as we trying to do anything the program closes and produces the following error: MYOB must terminate. Termination Code 1284 Important Details: Error -3000 in DMGTEKey (5037:7000:69) Seems to be the same error every time. We have tried running MYOB's Verify and Optimise tools with no luck. Each time either tool is run the program crashes and displays the error: An error occurred while attempting to compact the database. DM Error = (-3000-5049-7000-158) Restoring from a backup is not an option as last backup was 3 months ago. So looking for solutions to fix the current file please. Will not be satisfied if the solution is to take it to MYOB. Need someone who can actually dig around inside the file and correct the errors??
Apr 25, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
Restore problem on brightstor
the registry key SQLprotocol made brightstor use named pipes to restore which is not supported in SQL 2005.
Jan 14, 2009 | Computer Associates BrightStor ARCserve...
ARCserve Backup to disk Solution
Yes it is possible. You had to create the new media pool and added that in to particular new or current device group. and schedule your backup on that media of that device group . Cheers Parveen
Nov 27, 2007 | Computer Associates BrightStor ARCserve...
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Jul 26, 2007 | Sony (LIB81A3BB) AIT-3 Tape Drive
Computers & Internet Logo
309 people viewed this question
David Payne
David Payne
