Condensation problems water leaking out of bottom of unit
  • Anonymous Jul 08, 2008
    I have a window unit and I have water leaking in my house right under the air conditioner .What should I do ?
  • Anonymous Apr 15, 2009
    When my A/C unit has been running for awhile, the condensation starts to run out of the unit in my basement all over the floor, I don't know if this should be running outside. I do have a pipe that is supposed to run the water into my floor drain.
    New Friend:
  • 160 Answers
Get another brand like haier
Posted on Jul 08, 2008
The HPRO9XC5 unit leaks water from bottom of unit. Have had the unit for a couple of years and just noticed this today after using quite a bit during this summer.
Posted on Aug 11, 2010
4 Suggested Answers
dcp2
  • 63 Answers
SOURCE: Water leaking from portable air conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Posted on Jan 25, 2008
  • 105 Answers
First, make sure the unit is level. If so, you have a blockage or kink in the drain tube. Careful inspection should reveal any blockage, & you may be able to poke it thru with a piece of coathanger wire. Don't use excessive force, any block should be easily freed.
Posted on Jul 15, 2007
  • 166 Answers
SOURCE: sharp air conditioner portable leak in bottom
You mean it's leaking around the AC's unit base? If so, here's a handy diagnostic article that specifically addresses this problem of yours, explaining the probable causes and solutions, a solution that may very well have to do with the condensation pump's malfunction or just debris blockage, among other things: http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Creates_Water_Puddle.htm This article should set you on your way! Good luck! Brad
Posted on Jun 13, 2009
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
Our A/C unit when running, the drain water isn now backing up and leaking over the side in our basement. we've never had this problem before.
Hello, this usually indicates a clogged condensate line or cracked condensate pan. Try using a wet/dry by attaching one end of it to the otlet of the comdensate line, the suction pressure should dislodge the clog. If the line appears clean the the pan is cracked and will require a technician to come out and fix it.
Sep 06, 2011 | Goodman CKL36AR36 Air Conditioner
There is water leaking out from the bottom of my furnace. It leaks whenever the ac is running.
Hello, sounds like a clogged condensate line or a faulty condensate pump if the unit has one. Cleaning the drain line should fix the problem.
Jul 12, 2011 | Heating & Cooling
Internal unit is leaking water
Check condensate tubes - they may be blocked and need cleaning. All manufactures recommend having your furnace and air conditioner checked and cleaned on an anual basis. You can clean your condensate tubes yourself - if it is severly blocked you may have to use compressed air to unblock, but first to a combination of bleach and water. Better yet a technician will clean the condensate tubes and well as the rest of the unit so that it's running at its top efficiency
Jan 03, 2011 | Heating & Cooling
Water is not draining forom my hampton bay air condiotioner. It is gurgling and you can see water inside the unit. I have tilted it more in the window there is some water dripping but there is still water...
Allot of Window units do not have a drain anymore. The condenser fan picks up the water that lays in the bottom of the unit and slings it against the condenser coil to help keep it cool. If it is not leaking water inside the house it is normal to have some water in the bottom of the unit. This is verified by not having a drain hole or hose. As an A/C service tech I didn't care for this design as allot of people thought that there was a problem when there was not. They also tend to be a little noisier as the water makes noise when it is being thrown around inside the unit. I hope this helps
Jul 06, 2010 | Heating & Cooling
Airtemp - 25 yrs old. Water leaks from bottom of
Is the unit level? it's pulling moisture out of the air and not draining threw the drain hole normally it's cause by the unit not being leveled.
Aug 10, 2009 | Heating & Cooling
My Air conditioner leaks water
All A/C units drain water and need a clear path to drain water.
If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree.
If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
Aug 02, 2009 | Kenmore Heating & Cooling
Sharp air conditioner portable leak in bottom
Jun 13, 2009 | Sharp Heating & Cooling
Condensation leaking out of unit
if it is the indoor unit leaking, make sure that all your drain lines are clear.... if you're talking about the outdoor unit leaking water in the heat cycle...that is normal.
May 16, 2009 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
2,203 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
