Question about Grundig Classic 960 Shelf System
The string came off that runs the turner to change station do u have a picture of how the string is strung?
    Problem Solver:
  • 8 Answers
The main knob has exactly three turns on itthe string came off that runs the turner to change - possumn.jpgpossumn_1.jpgpossumn_2.jpg
Posted on Jan 30, 2011
I have a set of 11-48 12string i have never strung a 12string guitar before.can you tell me what string goes in what hole? 48 40 30 26 20 16 14 14 12 11 11 9
the Heaviest string of each string pair is placed at the top (closest to your nose). In fact, if you look at the nut, (the notched thingy that spaces and holds the strings at the right spacing up by the tuning pegs) the notches in nut are wider than the paired string for this reason. That may not be true on all 12 strings but it is on mine. So the typical arrangement is heavy string, matching string. Heavy String, matching string. Except on the bottom 3 pairs where the actual string thickness can be the same. One caution note here....when tuning a 12 string, tune it a whole step lower. So rather than tuning it at EADGBE, tune it at DGCFAD then use a capo on the 2nd fret to bring the tuning up to EADGBE.
The reason for tuning a whole step lower is because on the top 3 pairs of strings you normally tune the thinner string an octave higher to give that 12 string sound. So if you start tuning at EADGBE, those thinner strings for the top EAD strings are going to be pretty tight and they will snap. So much safer to tune a whole step lower and just use a capo!!! Good Luck
Nov 13, 2017 | Music
My crank string broke on my tempting crossbow what parts do I have to replace
You should only have to replace the crank string itself, I do not know of any other parts needed to do it. My cranks for my crossbows are very simple, crank handle, crank wheel with strung wrapped around it. If you are not mechanically inclined, then take it to your local hunting shop for repair. Good luck
Sep 19, 2017 | Archery
Huge amount of time between switching channels. screen goes black until it loads the station, then everything is fine. please help!!!!
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 23, 2014 | Sanyo 42 in. LCD TV
My goggles frame broken where can i get it repaired
yes, you can have them re-strung at any optical, or, you can even do it yourself if the string is still attached. If the string is not intact, they will remove it and re-string it. No problem!
--- chaitu_ganduri.... :)
Mar 11, 2011 | Cameras
Wireing turner plus 3 to president washington that is four pin
Wow I've never seen a six wire Turner + 3 anyway give this a try 1)shield & blue 2) white 3) black 4) red if the radio keys up as soon as you plug in the mic switch black and red . Good luck . Dan
Jul 23, 2009 | Magnum DeltaForce CB Radio
Poor dark picture on some movie stations
check cable box for input, whether it is 480, 720, 780, 1080.
Dec 08, 2008 | Panasonic PT-60LCX64 Television
Turner mode
To the right of the number 6 station preset is an auto/name button. In the display it likely shows something like auto 1 or 2. each press will cycle it through Auto 1 > Auto 2 > Manual. You want the manual setting. See if that works for you.
Mar 22, 2008 | Kenwood KDC-X717 CD Player
Can't get cable stations
you have to go into the menu and set for cable then scan for active stations.
Mar 15, 2008 | Televison & Video
Grundig Classic 960 Shelf System Logo
87 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
