Question about Amana ASD2522WEB (25.1 cu. ft.) Side by Side Refrigerator
I have a Amana side-by-side fridge model no.SQD23VW. My problem is that it won't dispense ice nor dispense ice water.Everything else works fine. Can you help
  • 4,323 Answers
Hi
Water and Ice not dispensing can be caused if water inlet valve inside the refrigerator is not opening. Also, make sure that the freezer temperature settings are not too high or too low, if it less than 17degree F it won't make ice. Determine if your water fill spout in the freezer is plugged with ice, blow hot air from your hair dryer for a few minutes to unblock it. Look behind the refrigerator if water is getting to the water inlet valve/coil behind the fridge. If the water is not properly connected, there's no water to make ice. If the valve is closed or if it is blocked, it will prevent water from dispensing. Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve. Next thing to check is water filter, you may need to replace it (you should change it in every 6 months). If you have changed it recently then you may need to prime the lines, it would take 10-15 minutes to dispense.Also remember that the dispenser in the door will not operate unless the fridge door is completely closed. If all of the above things are fine then it is due to a faulty "icemaker control and motor assembly" and you would need to replace it. Please check the exploded parts view for your refrigerator from this link---
Amana SxS refrigerator SQD23VW Exploded parts diagram
Hope this helps... Please post back if you need more information.
Daniel
Posted on Dec 31, 2010
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hooking up water to ice cube maker
On page 4 step 3 of the manual on link below tells you how to hook up the water supply for your fridge.
http://shop.amana.com/assets/pdfs/literature/004251.pdf
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
My whirlpool fridge/freezer
probally need to replace inlet vavle. first check to see if valve powers up when you hit lever to recieve water. you can hear valve humm if not then replace micro switch above the lever inside dispenser housing
Jun 07, 2009 | Amana ARS2464B Side by Side Refrigerator
Where is the filter on a Amana SQD23VW
CLICK HERE for all the blowout diagrams of your fridge.
CLICK HERE for your Owner's Manual in PDF format.
CLICK HERE for your Installation Instructions.
The water filter is found in rear right corner of refrigerator section. Twist cartridge counterclockwise 1/4 turn and pull down to remove.
Some fridge model levels did not have a filter and you will find a bypass cartridge there instead.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 06, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer problem
Have you checked the Heater element for the defrost to see if it's good? It sounds like the coils inside your freezer are freezing over into a solid block of ice which in turn will cause it to stop cooling.....efficiently. When you leave the unit unplugged, it gives the unit a chance to thaw and it work properly until the coils freeze over again. If heater is not the problem then Defrost Thermostat probably is. Both located in back of Freezer.
Nov 23, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana ASD2522WEB (25.1 cu. ft.) Side by Side Refrigerator Logo
194 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
