The stand-by light blinks 9 times pauses and does it again when trying 2 power on. i have unplugged it for over an hour and the problem continues. it finally came on yesterday but today i have no luck. sony rear video projector kp-46wt520 oct.2004 ser#8026062
    Genius:
  • 1,274 Answers
Hi modfan,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
If you have soldering skills, and equipment for electronics,
then replace the switching regulator.
Thanks for choosing FixYa.
Happy Holidays.....John
Posted on Dec 30, 2010
Panasonic TC-P55UT50 plasma went black. power light blinks 7 times, pauses blinks 7 times. Is this a power board? or Y-Sustain?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 06, 2016 | Panasonic Viera TC-P55UT50 55" 3D 1080p...
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My Sony Trinitron has stopped working mid viewing. The on/off/stand by light just flashes. Any idea how to get the TV back on?
You can try unplugging the TV power chord, leave unplugged for several hours, then plug back in and try it.
If no results you will need it serviced as there are many possibilities. If the light is blinking in a pattern, example flashes three times then pauses then flashes three times again, the number of times it is blinking can give the servicor a clue as to what circuit is at fault.
Oct 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
POWER STAND-BY LIGHT KEEPS BLINKING
part# 191002393 is the thermal fuse.Located on lamp housing.
Aug 22, 2009 | Televison & Video
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
RCA D52W19BYX2 power light blinks once pauses, blinks a 2nd time, pauses, and blinks a 3rd time. Wait about 65 secs and it will do it again. Happens whether I use the remote or the switch on the set. Also,...
try unplugging the tv overnight, then plugging it in when you want to watch it.
i guess there is some safety switch on the processor inside the tv itself that kicks itself on...stupid.
that is the only "band-aid" i have found that works
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony 62" Power TV Problem
Is your model KP61HS10? If so I can help you?
Jan 13, 2008 | Sony KP-61HS10 61" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
