Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Coffee machine when turned on will turn itself off after 3 to 5 seconds, then will not turn on untill switched off and on from power point. can someone please help ?. Coffee machine still under warrenty but David Jones will not repair or replace without a reciept which i have misplaced.
  • Iyed Alhajri
    Iyed Alhajri Oct 27, 2016
    hi there, I have the same issue my coffee machine is just doing the same thing. did you get fixed? thank you
  • 452 Answers
Motor problem by sound of it ...bsc appliances 07779933829 postal serrvice too.
Posted on Feb 26, 2011
Defuser unit stuck at bottom of Delonghi magnifica coffee machine. Squeezing red buttons does not help. Cannot remove
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Aug 21, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
We don't know how to operated . Could you help us please. What is the brew time period? In hour machine is said to put down the start for 2 seconde and to wait 3 click to decrease brew ? We cannot...
Normal brew level is about 64 ounces.Can be set to what ever airpot you have.To decrease brew volume 2 seconds in programming mode hold down brew button 2 seconds to decrease.Then hold brew button until you here 3 clicks then let complete cycle.turn off red on/off red power switch to lock in time.Set white dip switch on control board to locked position.
Nov 01, 2010 | Bunn CWTF 15-APS Coffee Maker
Coffee pot is not getting electrical current
Swich off at this power point pull out the plug on coffee maker and try another appliance that you know is working and try in this same power point.
If this second appliance works,you know for certain theirs a problem with the coffee maker.
The problem could be anywhere from the 3 pin socket on the coffee maker,the lead,themostat,overloads,or heater element/s.
Unless you are a competent electrical person repairs should not be carried out by yourself,
Even if do you will have to take it to get it meggered by a competant electrical person and a safety tag fitted to appliace, before you switch it on ,for the safety of everyone.
If the second appliance does not work, you know the problem is from the power point back.
Sep 12, 2010 | Cuisinart DCC-1200 Coffee Maker
No water/coffee comes through? the temprature indicators doesnt light up?
The POWER LIGHT for the 889 is RED and located on the LEFT of the center cowling
The BOILER LIGHT for the 889 is YELLOW and located on the RIGHT of the center cowling
If you turn on the power to the unit (the INNER SWITCH on the RIGHT SIDE) the RED light should turn on, showing that the machine is powered. At that point the YELLOW light should also turn on for about 10 seconds, at which point it will turn OFF with an audible CLICK.
If the RED light does not turn on then you have a very dead machine.
If the RED light does turn on but the YELLOW light does not then you have a half dead machine.
Opening up and repairing the 889 is not for amateurs. High voltage, heat and pressure inside.
If you decide to bin the machine I would appreciate getting the drip tray from you as I have lost mine.
Graham Leach
Sep 05, 2010 | Dualit Espresso 889 Espresso & Coffee...
Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to
May 24, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
Jul 15, 2009 | Cuisinart Coffeemakers
The Miehle built in coffee maker - I want to stop the cleaning process but it won't clear
1. turn unit off 2. open door, turn power off for 5 secs. ( switch upper left corner )  3. turn power back on, close door. 4. press and hold clear, press on/off. release both simultaneously. 5. immediately , press clear 5 times holding it down the fifth press until the display changes. 6. with menu available, press more until option to reset cleaning appears, select reset cleaning. 7. finished
Nov 02, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
Cuisinart DCC-1200 Coffee maker -
The machine is probably toast - but it's covered by Cuisinart's three-year warrany. Customer Service: (800) 726-0190. They charge $10 shipping, unless you live in California.
Jul 17, 2008 | Cuisinart DCC-1200 Coffee Maker
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
752 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
