Question about Tefal FR401615 Family Pro Deep Fryer
My On/Off, rocker switch is faulty (If I join the two read wires on the back it works fine). Do Tefal supply new ones and if so where can I purchase one and how much please ?
  • Tefal Expert
  • 684 Answers
You will be able to locate the nearest authorized parts and service dealer on your area by visiting
http://www.t-falusa.com
Regards.
Posted on Jun 19, 2011
Dual receptacles (hot all the time) next to dual rocker switches. One switch controls a light, the other a disposal. I've got three black and one white wire ( ground). The post set up on the rockers...
What are you doing? I can't figure it out.
I think you have a new double rocker switch and you are trying to replace a double toggle switch and you don't know which side to put your wires?
The screws are color coded. Look at the screw colors on old and new switches and follow same pattern.
If this is incorrect, answer back and I will help.
If you are adding another circuit.
That means running a new wire into the box to power another receptacle box, or to switch another light fixture.
If this is the case, the best place to connect any new circuit is the existing receptacle.
Connect new black wire to brass colored screw
Connect new white wire to silver colored screw.
Oct 25, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
HOW DO YOU REPAIR SWITCH ON A RAINBOW VACUUM?
Use a thin screwdriver or some other something like a butter knife and slide it into the gap on the side of the power switch. THis is just a plastic rocker that actuates the actual switch. Pry up on one side a little then the other to work it out. Don't worry if you break it, you can get a new one when you purchase the switch for around $5. Once you have that off, the switch can be pried up in a similar manner. It just unplugs from the socket.
You can purchase switch and cover rocker at goodvac dot com at a significant discount over other sites. Fast delivery too.
Oct 23, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My grandchildren's Feber Jeep (Famosa Toys) will not work. it has a brand new battery but the accellerator switch on the floor is not working. Any ideas where I can obtain a new replacement rocker...
hi, i have a 2 seater famosa blue jeep. the wiring that connects to the batteries wiring 2x6v 12amh is present but the link wiring is not?! to clarify the existing wiring loom is there but as the jeep requires two 6v the wire joining the batteries is not present, can anyone help. i have photos if they need to be emailed, regards, gareth
Sep 12, 2010 | Feber Toys
Fisher and Paykel GW703 OOB Switch Fault I've diagnosed a OOB (out of balance) switch fault with a GW703 washing machine from the error code 00101011. I've checked the switch and it moves freely and clicks...
Hi just read your posting.Now the easiest way to check to see if the problem is your oob switch is to join the two wires that go to the switch with a small piece of wire so there is conductivity between them.This will bypass the switch and if you still have a problem then it could be your motor controller or your rotor position sensor.Please try the joining of the wires and see how you go.If it rectifies the fault then change the switch, if it does not rectify the fault then I can help you further when you reply back.Please turn the power off at the wall before you do this bypass.Make sure when you join the wires you tape up the joins with tape to stop them shorting out on something.When you have joined the wires try a cycle and see how it goes.Hope this helps.
Jul 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Reverse lights only work sometimes on isuzu wizzard
Manual gearbox: check on right hand side of gearbox. There's an electrical switch(looks like large nut nut) with 2 wires coming out of it These wires have connectors toward the top of the gearbox, diconnect them.
The wires that this switch was connected to, conect them to each other. ie the reverse light switch has been bypassed. Put the vehicle in reverse. Turn on the ignition. DO NOT START. Check the reverse lights. If on the switch is faulty and needs to be replaced. If not measure the voltage across each of the wires and a good earth point. (Gearbox casing will do fine. ) One of the wires should read < 12V.
If 12V then
  • Globes are faulty(Replace)
  • wiring to the globes are faulty - unlikely -(This can be repaired by simply running a new wire to the globes)
If no 12V then the wiring to the fusebox is faulty. A quick fix is to run a new wire from the fusebox to the switch(Connect to fuse C-3, indicated as "turn, back")
May 31, 2010 | 1998 Isuzu Trooper
I need a new on/off rocker switch for my Tefal FR4016. Does anyone know where I can buy one please? I know how to fit it and what the cables are, I just need to locate a new switch. Thanks
Worst product I ever bought switch broke within 1 week, used twice and Teefal/Currys were about as helpful as an unhelpful thing.
Anyhow got a switch from from CPC www.cpc.co.uk PN: SW02922 Desc: Switch, rocker, spst, red, 250VAC £1.20 each.
Fitted works like a dream and seems a lot sturdier than the cheap one supplied with the unit.
Hope this helps others. Never buy another Teefal product!
Feb 25, 2010 | Tefal FR4016002 Deep Fryer
Oven lights don't light. replaced, but no light. panel is good, heat works. Clock is accurate; only lights won't light when door open.
there should be a switch around the frame where the door closes. take that off. then disconnect the two wires. then join the two wires together, if light works then the switch is faulty. get a new one and replace. also make sure the new bulb you replaced is the right one and not faulty.
Jan 10, 2010 | KitchenAid Kitchen Ranges
I have an ariston lsi 45/50 which will not end it's wash cycle.i have checked the salt level,which is fine. Any ideas please?
HI Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.,,,,,,,,,,,,,,,PLEASE RATE IT..........THANK U
Nov 28, 2008 | Dishwashers
I have a 4 slive tefal deluxe toaster which has stopped working
often is the switch as you press down its a steel wire like a pin that snaps i have repaired 2 same problem i soldered a fine steel wire on its easy part to replace but so far i cant buy a replacement switch
Sep 08, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Tefal Oven faulty LCD DISPLAY
Hi babypom,
No, the LCD display is a whole piece and need to purchase from the agent.You've to confirm there is LCD voltage, but no display light, to justify is LCD faulty.
Rdgs
alan
Feb 18, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Tefal FR401615 Family Pro Deep Fryer Logo
124 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
