Question about Pioneer VSX-D810S Receiver
I can't seem to get the optical inputs to work with either the output on my set top box, or the audio output on my HDTV. Is there something I'm missing that enables the inputs.
  • 736 Answers
I apologize if you have already done this but it was not in the description so I am suggesting it. On the set top box change the audio output setting from hdmi or pcm or whatever it is currently to bitstream or optical. If all of the audio outputs do output all at the same time on your set top box then this does not apply.
As for the television it does not function as a "center channel" so to connect it to a receiver with optical and get sound out of the external speakers you would have to be running digital cable straight to the television with no cable box or an over the air antenna.
Sometimes you can get an external device to work that way using the television as the center channel but more often than not you'll have to connect each device to the receiver, which is what you tried when you connected your set top box to it.
Posted on Dec 30, 2010
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: http://resources.jvc.com/Resources/00/01/14/YA653ien.pdf . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
How do I change the settings to 740 p or 1080?
Hello
1Connect the video outputs (Y, PB, PR) of the digital
set-top box to the COMPONENT IN VIDEO
jacks on the set.
Connect the audio output of the digital set-top box
to the COMPONENT IN AUDIO jacks on the set.
Turn on the digital set-top box. Select Component 1 input source with using the
INPUT button on the remote control.
- If connected to COMPONENT 2, select
Component 2 input source.
Feb 20, 2011 | LG 42LC2D 42 in. LCD HDTV
Which optical inputs should I use for (1) audio output from hi-def cable box (connected to HDTV with component cables) and (2) audio output from DVD (connected to 3805 with component cables?
Hi, the Optical and Coaxial inputs are assignable to whichever input you need them on. Plug the Optical cables from your DVD and HD cable box into any of the OPTICAL INPUTS (1 and 2 is fine, but write down your connections on paper)
You will then need to go into the setup of the AVR on the screen and assign the OPTICAL connections to the correct inputs (Probably TV/CAB and DVD.
Use the SYSTEM SETUP button on the factory remote, and you should see the on-screen menu appear on your TV. Go to INPUT ASSIGNMENT and choose the input for the DVD and assign OPTICAL 1 or 2...
Reply here if you need more help.
Jul 06, 2009 | Denon AVR-3805 Receiver
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
I need a digital audio cable to connect to my surround sound amplifier from vizio HDTV (digital audio output connection)
yes and no. most set top boxes have a optical output that can go to the vizio, but you can also connect a regular right and left audio cable too. Now from your set top box or cable box or sat box you can go to receiver in digital cable. that is the better way to go.
Apr 01, 2008 | Audio Players & Recorders
Set up
Seems that Hitachi DESIGNED the sound to cut off from the Audio Out jacks if you use component video or HDMI inputs. Has to do with copyright laws of the HD Video -- which makes it asinine that they disabled the audio as well, as it's not part of the copyright issue. Seems to me they were just lazy to disable the ENTIRE set of output jacks.
I am hoping to find some sort of hack for this (either firmware or severing/splicing a control wire). However, I can't find much information on this yet.
Sep 14, 2007 | Hitachi P42H401 42 in. Plasma HDTV
Open Questions:
See all Pioneer VSX-D810S Receiver Questions
Pioneer VSX-D810S Receiver Logo
64 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
