Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Chamberlin wireless opener model 940CB i need to change the code but i do not know the old code how can i do this
    President:
  • 3,197 Answers
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Dec 30, 2010
Changing code on keypad
i have a lift master chamberlin garage door opener and need to change the code on my key pad outside, k\my problem is i have no enter button when i put my new code in on my key pad, does anyone know how to help me change my code on my keypad without the enter button....there is a pound and star button
Jan 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener, of which I tried to program a new remote. but it did not program. in the event I accidently errased my keypad password. How can I reprogram the keypad, i cannot...
Hello there,
It actually depends on what you are trying to program. And these instructions apply only to openers that do not have dip switches on them.
Remotes: push don't hold the colored learn code button all models have different colors. After pushing the button hold the remote behind your back and push it three times. On the third time the door should run.
Keyless Entry: Program the code you want into the keyless. Push the colored learn code button and then enter the code and push enter three times slowly. on the third time the door should run.
Home-Link. Hold the two outer buttons until the blinking pattern changes. Then hold the button you wish to program and point and click your remote at it. Push the colored learn code button and push the homelink button three times.
There are two models of the Wireless Keyless Entry System, the 740CB and the 940CB. The 940CB is for use only with Security+® garage door openers having an orange/red smart/learn button. The 740CB will work with all openers manufactured since 1990 that have a yellow, white, gray, or green smart/learn button. It will not work with Security+® openers.
To program the keyless entry, first locate the smart/learn button. On our chain drive models, this button is on the end farthest from the door. On our belt and screw drive models, it is on the right side as you face the door from the opener. You simply press and release the smart/learn button. You now have 30 seconds to enter your four digit PIN number into the keypad and hold the enter button for five seconds. Wait one minute and test the keyless entry by entering your four-digit PIN number and pressing enter.
With some Security+® models, you can also program your Model 940CB Wireless Keyless Entry without climbing a ladder, right from your Multi-Function Control Panel. Simply enter your pre-selected code and press and hold the enter button on your Keyless Entry. Then press and hold the light button and the pushbutton on your Multi-Function Control Panel. The garage door opener lights will flash to confirm that the Keyless Entry has been successfully programmed.
Hope this helped you solve the problem. All the best my dear friend. Elect_Comp
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need to reset my garage door code i have a chamberlin how do i change the code
Apr 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
Need to change the code on my key pad
Here is a link to the instruction manual Chamberlain 940CB wireless keypad look under Chamberlain Liftmaster garage door opener manuals - Other types
Jan 06, 2011 | Chamberlain 940CB Security and Wireless...
HOW RESET CODE FOR 940CB/67LM CHAMBERLAIN OPENER,
The learn button is the first button to the right of the LED.
May 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have 1half h\p chamberlin garage door opener
Unplug the opener and remove the bulbs. Use a small screwdriver to pull out on the center contact in the socket. Make sure you are using standard bulbs.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I just bought a house that has a wireless keyless entry model 940CB. I do not know the previous owners password. How do I change the password without the old password?
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Apr 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unplug the unit and remove the bulbs. Using a small screwdriver pull out on the center connection in the socket.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
HOW RESET CODE FOR 940CB/67LM CHAMBERLAIN OPENER, DONT SEE LEARN BUTTON ON LIFT MASTER OPENER MODEL MT 5011
The learn button is just above terminal 3 on the terminal board. You might want to call Chamberlain Technical Support Helpline at 800-528-5880 with that opener.
Mar 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you change the code on the keypad for a sears/chamberlin garage door model#13953615SR
On the back of the motor unit near where all those white wires go you will find the smart/learn button. Press and immediately release this and walk over to your keypad and key in any 4 digit number you desire and press enter. Your code will be changed.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
125 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
