Question about Mtd #TB4SC 25CC 4-Cycle Gas Blower
While running what setting does the choke lever need to be placed in
  • 885 Answers
Depending on how your unit runs, it may need to be on half choke until the motor warms up. After the motor gets hot it should run with the choke fully off.
Posted on Dec 30, 2010
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
How come weedwacker tries to crank while on choke but when you move lever to 2nd position it tries to crank? but wont
When mine does that I go back and reprime repeating the process. It seems the gas does not feed up fully with the initial priming effort. Once it starts I move the choke lever quickly on way or the other to see if I can keep it running until it gets warmed up. Sometimes I have to adjust the choke setting even after it has run for a while.
Sep 21, 2014 | Craftsman WeedWacker Gas Trimmer 25cc...
How can I free both the stuck choke pullout lever and the on/off switch on my Poulan Pro 18" chainsaw? I tried using the start handle pull to rotate the engine, which turns normally, but switches are still...
This is a carburetor linkage problem and pulling engine though with the starter will not have any effect.
Check all the linkage at the carburetor for problems. Also try pulling the throttle trigger and may sure it operating the carburetor.
Aug 14, 2014 | Poulan Garden
Choke leaver is brokin off bought choke kit how do u replace
there is a little pin in the very back of the choke lever you push that out and pul the old lever of and put the new lever in its place and put the pin back in
Dec 03, 2011 | Polaris ATV
Hello folks; My Husqvarna yth 2348 rider is very hard to start on the initial start. After once getting to run, it restarts easily with little hesitation or need of choke usage. Help please on how to start...
Sounds like your choke cable needs adjustment. Follow the choke cable to where it mounts on the carb.
Move the choke lever at the same time watching where it mounts to the carb. there is usually a clamp holding the cable in place, you may need to loosen the clamp and slide the cable back to make the choke fully close
Aug 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
What position should the choke lever be when starting a cold 1986 Shadow motorcycle?
The rubber cover can be tightened or loosened to hold the choke lever in place. I like to set the rubber cover just tight enough to keep the choke out but if I start driving it starts to slip back in by itself. If you pull the plunger all the way out it will raise the idle and should be the best position for the initial start. You may find you have to touch/ twist the throttle just a teeny bit to get the first pop. Then run full choke for the first 10-20 seconds till the fast idle is steady. Then push in the choke till you have a slower more comfortable fast idle. At 45-60 seconds push the choke in just enough to keep it idling. It should be safe to slow drive with the choke out about a quarter of the way. Take the choke off completely when the bike will idle on it's own 1 to 2 blocks down the road. If the bike is still boggy on take off put enough choke back on to get a smooth take off , then while slowly cruising during warm up push the choke all the way back in. Take it easy till the engine is warm.
Mar 02, 2011 | 1986 Honda VT 500 C Shadow
I have an aldi powercraft generator pc3200dv/10 i can start it but it cuts out after a few minutes ,i am finfding it hard to find the fuel valve also it runs for the few minues with choke on but if you...
Hi there, YES manual VERY misleading, starting it all revolves around the Choke, if I remember correctly, place lever on Choke, start then move lever to on position, good luck
Dec 30, 2010 | Electrical Supplies
I took apart my new stihl ms 210 the throttle assembly anyway, where does the black wire connect to? there is a red wire connecting to a metal bracket that is coming from the same hole the black one is i...
On the Master Control Lever, you will notice a round reciever on the left side of the lever shaft. This holds the round terminal of the black wire in place. As the lever is rotated upward, the shaft brings the terminal of the black wire into contact with the flat brass spring (which belongs ON TOP of the lever shaft) and thereby stops the engine.
If the throttle trigger is pulled each time the lever is set to choke, this will never again be an issue. However, if the lever is pushed all the way down to choke and the throttle trigger isn't pulled, the linkage will malfunction again.
ALWAYS pull the throttle trigger before you set the choke.
Hope this helps,
Dolf-
Oct 14, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Will not run unless on choke
carb needs to be rebuilt and fuel filter changed in gas tank
Aug 13, 2009 | Garden
Mtd #TB4SC 25CC 4-Cycle Gas Blower Logo
186 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
