Question about Hotpoint Washing Machines
Hotpoint ultima 1400 wm73 fault no E30 - Hotpoint Washing Machines
  • 1462 Answers
SOURCE: hotpoint ultima 1200 wm72
code e30 means motor fault. this can be just motor brushes, tacho fault or module fault. can't narrow it down more than this - you will have to dive in and check
Posted on Apr 10, 2007
  • 121 Answers
SOURCE: fault f10
the manual can tell you the problem you can get this here
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Posted on Mar 03, 2008
barkencoa
  • 3463 Answers
SOURCE: HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
SOURCE: Hotpoint WT965 ultima fault code
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Posted on Jan 07, 2010
Cannot get clothes out meesage e30 what can I do?
Hi, E30 indicates a fault in the motor circuit, unplug the appliance and take the top off. Either side of the motor you'll find a carbon brush holder. Disconnect the wire to the carbon brush and take the holder out. If worn or broken, replace with new ones.
Jul 14, 2011 | Hotpoint Ultima WD72 Front Load...
Hotpoint Model WM75 Error Code E30 (Motor Drive problem)
what does e30 mean on wm75 hotpoint ultima 1200
Dec 02, 2010 | Hotpoint Washing Machines
What is E30 ?
E30/31: Motor problem - check motor brushes, drive belt, tachometer or tachometer magnet, motor relay or PCB (TRIAC motor control).
Jan 28, 2010 | Hotpoint Ultima WD72 Front Load...
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
I have a hotpoint ultima 1000 coming up with E30 problem. can you help, I do not have a manual.
Jan 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 1200 wm72
Apr 05, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
127 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
