Question about Cannon Office Equipment & Supplies
Printing cropped off on right side of page, only sometimes.
  • Cannon Master
  • 17,129 Answers
Possible that the printer needs a reset., So it will be good to remove/disconnect the printer from the PC. now un-install the drivers from the PC and then reinstall the drivers using the original or from the website.
Connect the printer to the PC as it will detect and install the hardware.
Now the setting would have resetted as you can see the ink levels and the settings.
take a trial print to confirm .
Wishing you a happy and prosperous New Year.
Posted on Dec 31, 2010
Booklet margins being cropped
You don't need the original HP install disc. Go to the H Support site and download and install the newest one listed for your operating system. Turn the printer off and unplug it, wait 10 secs and plug it back in after installing the latest driver and software. Should work fine for you.
Oct 13, 2014 | HP LaserJet 1200n Printer
Image not fully printed
Easiest thing to try first is your printer settings, where you should be able to select the exact paper size (8.5x11,legal, 4x6, 5x7, etc.). You also may need to look at the 'resize' options (fit to page, print as is, etc.). You can usually easily get to printer settings by using menu bar command File-->Print , then selecting the [Printer Properties] or [Properties] button in the pop-up print menu.
Dec 02, 2013 | Office Equipment & Supplies
It prints only half a page.... how can i fix that???
Does the print fade out or is the printed page complete, just cropped down? If it is fading out then it is the cartridges running dry, or refilled using the incorrect ink. If it is printing the entire document, just smaller, then under printer properties you can set the page size. (control panel - printers and faxes - right click your printer and select printing preferences) I hope this helps Regards GM
Apr 13, 2011 | HP Photosmart C6180 All-In-One InkJet...
I am unable to print excel spreadsheet - no facility to remove grid lines and as a result it wants to print a small spreadsheet into 666 pages
I can see the page in excel with data i want to print but when i want to see the print preview or print the page, i am unbale to access the page. some fixed pages crops up for print preview or on printing the page
Nov 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
More than one paper at a time
Are you saying that the printer pulls in too much paper at a time, or that it's actually printing on more than one page, even if you only want to do a single page? If it's pulling in too many pages, try fanning the paper. At times, especially in low humidity conditions, paper will tend to stick together and then several sheets get pulled into the printer. Fanning will often relieve the symptoms. Also make sure that the feed roller is clean. Use a cloth with some alcohol on it and rub the tire all the way around or as much as possible. See if that works.
Jan 28, 2009 | Canon BubbleJet i550 InkJet Printer
Picture crops strange
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Dec 08, 2008 | HP PhotoSmart 7550 InkJet Printer
Printing Problem
My first copy comes perfect second copy the yellow color is getting shake
Nov 20, 2008 | Xerox DocuColor 12 Printer
Vertical line down right hand side
crop toy jpg or bmp file from that side and then try I faced smae type of problem that process helped me you also try.
Mar 18, 2008 | HP LaserJet 1012 Printer
12 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
