Question about Vacuums
Unit will start but will shut down in 5 seconds or there about
    Problem Solver:
  • 15 Answers
Check the filter, this happens if the same is dirty. If it is clean, ck all parts of the hose for obstruction. This is a safety cut out.
Posted on Dec 30, 2010
Powerhead on vacuum shuts off after about 5-10 seconds of use. What is cause?
There are several possibilities, some of which you seem to have already checked.
1) The filters are clogged. System will cut out quickly if there is little or no airflow, to prevent overheating.
2) There is a clog somewhere besides the filter. Run through the checking for clogs steps in the manual, page 6. (
https://www.dyson.com/parts/u/user-guide/medialibrary/9118C278B029492DA662A45A70F187B0.ashx )
3) There is a small, Hall-Effect sensor near the filter that detects that the filter is in place and seated properly. If it is faulty, or the filter ISN'T seated properly, it cuts the power. Replacing that is beyond the scope of what I can safely advise on.
4) There are temperature sensors for the unit. If it's too cold, or too hot, no power. Too hot means the system thinks the battery is overheating, which can be dangerous. If the temp sensor is bad, that could do it too. This is also past what I can really help you on.
Good Luck!
Apr 20, 2015 | Dyson DC21 Motorized Power Floor Tool
Hello, I have a Dyson DC31 and she keeps shutting down. Most of the time she will shut down as fast as you pull the trigger, other times she will only power up for about 5 seconds before shutting back...
Hi there, it's Jack at Dyson.
If you need some help with your DC31 Animal handheld, we'd like to put you in touch with our experts for some diagnostic checks. Can you let me know where you're based so I can supply the correct contact details?
Oct 26, 2013 | Dyson DC31 Bagless Handheld Vacuum
Vaccume shuts off after 5 minutes of using. will only start after sitting for hours.
This sounds like an overheat condition. You must have plugged air flow, so rather than cause a fire, the unit shuts down until cooled. Find and remove the blockage << Not always an easy task.
May 21, 2011 | Hoover U5753-900 WindTunnel Bagless...
My Dyson DC16 usually shuts down after about 5 to 10 seconds. However, occasionally it will run for 45 seconds to 1 minute before shutting down. It is left on charge permanently. I have checked the...
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Mar 23, 2011 | Dyson DC16 Root 6 Bagless Handheld...
After running for afew minutes it shuts off ??
filters plugged. possible unit plugged at floor inlet also.
May 06, 2010 | Dyson DC25 All Floors Bagless Upright...
I have the same problem as steve967 The dyson dc16 is fully charged, runs well for 5-10 seconds and shuts down. I wait for a second or 2 and it runs again for 5-10 seconds. This will continue for...
Dear Michael_Stad,
I am going to sound like a broken record but here is my same answer to another person with the same problem.
I have I had the same problem with my Dyson DC16, where it only runs for a few seconds at a time with each trigger pull. My husband called Dyson (Canada) and without hassle they shipped us a replacement part which I just received this morning. The replacement part sent to us is: DC16 Main Body with Rating Plate. It is also under warranty for 1 year. The great customer service makes up for the flaw in the machine. Also, Dyson is aware of the problem. Hope this helps.
Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Dec 14, 2007 | iRobot Roomba Red 4100 Bagless Robotic...
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
