Question about Skytech 3002 Fireplace Remote Control with Thermostat
Our Skytech remote beeps (Inside the fireplace) when the fire is burning........why?
3 Suggested Answers
SOURCE: skytech model no. sky-3001 changed batteries in
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Posted on Jan 01, 2011
  • 4736 Answers
SOURCE: I have a Skytech 1001
Rhonda, if you have the On/Off/Flame Height Remote Control ... from what you have described (it's working in reverse) someone has wired it backwards to the control valve. With this particular remote, there is a positive and a negative. Reverse the wires that are connected to the gas control valve (at the control valve. Not on the Black Remote Box) and everything should be fine. If you need more help contact Skytech Technical Service @ 888-672-8929 Monday - Friday. They are great people to work with.
Posted on Jan 15, 2011
Remote for SkyTech Un3 will not work, need Manual
I have a direct link to the Skytech 1001-A owner's manual on my site here: Skytech 1001-A Fireplace Remote.
Simply scroll down to the bottom of the page to the "Download Owner's Manual" section. I try to keep it updated if the link ever changes.
Thanks!
Dec 28, 2012 | Skytech 1001-A Fireplace Remote Control...
Need Manual for SkyTech Remote UN3
You can visit my product page here: Skytech 1001-A Fireplace Remote. Simply scroll down to the bottom where it says "Download the Install Manual", I keep an updated link to the owner's manual.
Thanks!
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
Skytech-3001 Thermo won't work
I am having some trouble! Mine became unconnected and I don't know how to reconnect. There is two wire, red and white, a box that sits inside the fireplace that has an on/off sitch and a box that sits outside the fireplace with a off/remore/on switch. How do I connect it back? Please help!
Jan 28, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
The remote no longers turns on the fireplace.
  • Is your valve turned "on" and not in the "pilot" mode?
  • If your valve is in the "on" position, try turning the Skytech receiver's switch to "on" instead of remote.
  • If the fireplace ignites when the receiver is "on" then the remote needs to be re-synchronized.
  • If the fireplace valve is "on", the remote's receiver is in the "on" position, and the fireplace will not light, then you most likely have a bad thermopile in your fireplace and need service.
  • Skytech 1001-A product page and manual can be found here.
Dec 09, 2011 | Skytech 1001-A Fireplace Remote Control...
My skytech remote is blank I have changed the batteries what else can I try?
The Skytech 5301 Fireplace Remote's touch screen should never be blank, especially if it has fresh batteries (assuming they are installed in the correct orientation).
Skytech offers a generous warranty, you should contact their support team at 1-888-672-8929 to request service on your remote.
Sep 14, 2011 | Skytech 5301 Black On/Off Wireless...
My remote won't control the fireplace. Do you have to program it
Normally, it comes programed. Before trying to reprogram it ...First, be sure you have the leads from the black receiver box connected to the proper terminals on the control valve of your gas fireplace. Secondly, be sure ALL the batteries are installed properly (i.e. facing the right direction). Do you get a beep when you press the Mode button on the hand held remote? If you do, the problem is some where else.
If you gas fireplace has a rocker switch in the control compartment that was used to turn the burner on and off ... Is it a 2 position switch or a 3 position switch? If it's a 2 position switch, be sure it's in the ON position. If it's a 3 position switch, it should be in the middle position. Is the gas control valve knob turned from Pilot to the ON position? Is your Pilot Light burning? It has to be for the remote control to work.
To test the whether or not the remote is connected properly, push the slide switch on the front of the black receiver box to the ON position. If you pilot is burning and the control knob for the burner is in the ON position, the burner should then light. If it doesn't then I suspect the wiring from the black receiver box to the control valve is not connected to the proper terminals. Or a rocker switch is in the wrong position. If all this fails contact SkyTech Technical Service @ 888-672-8929.
Jan 10, 2011 | Skytech 3301 Thermostatic Gas Fireplace &...
Skytech 3002 Fireplace Remote Control with Thermostat Logo
215 people viewed this question
Top Skytech Home Security Experts
Tom Chichester
Are you a Skytech Home Security Expert? Answer questions, earn points and help others
