Question about Whirlpool Washing Machines
What dose f1 code mean on cabrio washer - Whirlpool Washing Machines
    President:
  • 3,113 Answers
F1 usually means a communication or an electrical error.
Unpgug the machine for 1 minute and then power back up. If fault reoccurrs check all connectors.
How long have you had this machine? Has it always been plugged into the same outlet? Is is sharing an outlets with another device?
Posted on Dec 30, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Posted on Feb 14, 2009
SOURCE: I have a cabrio whirlpool washer and a F1 code
i just called on mine for the f1 code and they said its a defect and would fix it call 18002531301
Posted on Oct 04, 2009
  • 2128 Answers
SOURCE: F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Posted on Dec 13, 2009
  • 122 Answers
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
Posted on Aug 22, 2010
  • 160 Answers
SOURCE: What is code F1 mean on the Whilrpool Cabrio. The
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Posted on Jun 02, 2011
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
    Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
    Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
    F1 (F60-68)
    Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does code f1 mean
    Hello
    Error code F1 means that the control of washer has either gone bad or about to go bad. This is a common issue with Whirlpool Cabrio washers. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge for the part. Please get back to me if you have any other questions.
    Kevin
    Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does F1 mean for a whirlpool cabrio
    F1 error code is for main board failure, replace main board
    Sep 07, 2010 | Washing Machines
    Whirlpool Cabrio is showing a error code of F1 what does that mean?
    Typically, we're going to be looking at a pressure sensor failure here, although there are a few possible culprits. There's some pretty detailed troubleshooting here:
    http://www.managemylife.com/mmh/questions/195601-why-does-my-whirlpool-washer-model-wtw6500sw1-display-the-fault-code-f1
    Jul 15, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 code whirlpool
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have a cabrio whirlpool washer and a F1 code keep's on coming up what doe's it mean
    Oct 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    f1 code means the main control needs to be replaced. pretty common repair
    Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washing Machines Logo
    51 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
