Question about AOpen DUW-1608/ARR Chameleon 16x4x16x DVD+R/RW 8x4x16x DVD-R/RW 42x32x42x CD-R/RW 2.4x DVD+R DL Dual... (ODDWAOUW1608) Burner
My dvd player starts then stops and the light keeps blinking.Can someone tell me what's wrong?(AOpen DUW-1608/ARR Chameleon 16x4x16x DVD+R/RW 8x4x16x DVD-R/RW 42x32x42x CD-R/RW 2.4x DVD+R DL Dual... (ODDWAOUW1608) Burner)
  • AOpen Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Dec 30, 2010
I need to download a driver Apopen DUW 1616/ARR DVD RW that will work with windows 7 64bit. Do you know where I can find them?
dvd rw drives do not need drivers installed to be able to use it for windows 7, if your drive is not working under your operating system(windows 7)
here is the link from the manufacture of this device, only shows firmaware upgrade and manual downloads.
http://global.aopen.com/products_detail.aspx?auno=1359
Nov 23, 2016 | Computers & Internet
DUW1616/ARR DVD Jammed
Can't you just push an opened out paper clip in to the eject hole on the front of the tray cover. It should be just above the eject button.
Jan 31, 2012 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Can I open a jammedDUW1616/ARR DVD
Look on the front of the tray where the eject button is There should be a small round hole, this is for ejecting a stuck disk. Just open out a paper clip and insert in to the hole and press until the tray opens.
My dvd drive starts and then stops and the light keeps on blinking.Can anyone help me with this?.....(AOpen DUW-1608/ARR Chameleon 16x4x16x DVD+R/RW 8x4x16x DVD-R/RW 42x32x42x CD-R/RW 2.4x DVD+R DL Dual......
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 30, 2010 | AOpen (DUW1608/ARR) (914ID37202) Burner
After installing AOpen are Drivers FREE?
The drivers should install automatically once the optical drive is installed. (Assuming good power and data cable connections) This optical drive may have come with a CD/DVD burning program when new. If you have the original CD, you may be able to use that program depending on your OS.
Otherwise, there are several free DVD burning programs but your OS and willingness to deal with "extras" may limit your choices. Nero Lite is free if you accept the Nero Ask Toolbar: http://www.nero.com/eng/downloads-nero9-free.php . This should work with all versions of Windows. Ashampoo Burning Studio is well liked by many: http://download.cnet.com/Ashampoo-Burning-Studio-Free/3000-2646_4-10776287.html . This is for XP, Vista and Win7.
Basic drag and drop burning of data to an optical disc is included in Windows from XP up.
I hope that this helps.
Apr 09, 2010 | AOpen Chameleon DVD+/-R/RW 16x16 dual...
Drive light gets stuck on at reboot
Try swapping the Jumper block ( Small plastic pin connector ) on The Back Of the DVD Drive. If using both Hard-Drive And DVD Drive on the Same IDE Cable. The DVD Should be set as Master And Hard-Drive As Slave, Or Vice versa.
Failing This, put The Hard Drive On Primary IDE Channel, And DVD On Secondary Channel.
These suggestions, have been made as it appears from your problem listed, that the 2 drives Are Conflicting with each Other.
Finally, is to try a different 4 pin ( Molex ) power cable to either device/Drive. if you have a single rail Power supply unit. the 2 units sharing a joint power cable, may be draining the PSU.
Hope this helps.
Mike @ compurepair.
May 11, 2008 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Drive Can't Burn DVDs
If it is a combo drive then you cannot burn DVD's with it.
A combo drive can burn CD's and play DVD's
If it is a burner, then install Nero and burn DVD's with that. But as above, if it says it's a COMBO drive, then it can't.
Apr 21, 2008 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
READ DVD
if u got a cd with ur DVD RW u neet to install the drivers and then reboot the pc
Oct 12, 2007 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
Aopen DUW1608/ARR Problem
Right click on my computer>properties>device manager>hardware and look for line saying cd/dvd drives and highlight your dvd burner. Right click it and click uninstal. Restart your pc and Windows will automatically re install it. See if this works, if not either needs a lazer clean disc or you need to replace it they are cheap these days.
Nov 02, 2006 | AOpen DUW1608/ARR (914ID37204) Burner
Won't burn
Check which flate cable do you have for its connection. AOpen recommendation is for 80-wire ATA-66/100 cable. In case this is not the cable you have, you should replace it. (The ATA/66/100 IDE cable is made from 80-conductor wire with 40 pin connectors, providing the superior ground spacing required by the ATA/66/100 specs, and allowing the full 100 Mbps burst transfer rate). Another AOpen recommendation is to configur the unit as a "Master" and not as a slave. Good luck
May 05, 2006 | AOpen DUW1608/ARR (914ID37002) DVD±RW...
Computers & Internet Logo
122 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Iqbal Husain
Iqbal Husain
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
