Question about Kenwood VR-6070 Receiver
My 6070 acts as a switch between various audio/video inputs and the sound system and video elements. In this case the video element is a Benq 770 projector. The video/audio inputs are a DirecTV receiver, a DirecTV digital recorder, and a Panasonic dvd player. This configutration has been playing for years. I now want to add a WII game to the Switch matrix to be able to switch in the WII game to the amp and the video projector. The inputs from the WII to the Kenwood switch matrix are baseband video and left and right audio. I have inserted thes into the inputs at CH 1. The video runs to the Benq via S-Video. All other switch channels work ex the WII video to Benq. When plugged directly into the Benq, the video signal is projected correctly. I am trying to figure out why the WII-Kenwood-Benq connection that I have doesnt work.
  • bob7547 Dec 30, 2010
    The only link I have between the Kenwood and the Benq isthrough walls and ceiling via S-Video. I need to know how to get the baseband video from the WII to convert to S-Videeo.
  • bob7547 Jan 02, 2011
    The only link between my Kenwood and the Benq is vis a 20 ft run in the walls and ceiling.
  • 6,826 Answers
Sounds like the Kenwood vr-6070 should be bypassed for the video, and note which video input is used for the Wii and the Benq, Good luck on this.
Posted on Dec 31, 2010
  • 2,386 Answers
Hello
Try composite video signal instead of s-video. it will definitely work.
Good Luck
Posted on Dec 30, 2010
Stereo only playbacks in mono. it used to play stereo
Stereo is actually two identical amplifiers which when the left and right of a stereo signal is fed into the respective inputs will reproduce the stereo sound through the left and right speakers.
Mostly there is a mono/stereo switch so if only a mono signal is available it is reproduced through both speakers.
You don't make it clear whether the playback is in mono or half a stereo?
If playback is in mono it will emerge from both speakers but the directional element will be absent. If the playback is in half a stereo the sound will emerge from one speaker only or mostly one speaker.
Most common problem is the failure of one of the amplifiers which could be electronic or the failure of any of the various switching usually used in such things.
The amplifiers can be tested by injecting a signal into each amplifier input and will be found satisfactory if the sound emerges from each speaker in turn at a similar volume.
Sep 01, 2017 | Audio Players & Recorders
I have a element TV model elef w605 no picture but have sound
Check your inputs to make sure you audio and video are on the same input.
Dec 12, 2015 | Element Televison & Video
What motherboard is used?
Asus Z97-A ATX LGA1150 Motherboard
Dec 08, 2015 | Computers & Internet
Using turntable (audio technica at-lp 120) with built in pre amp the sound is distorted and broken up. the turntable requests phono turned on to use. Does the receiver have a pre amp or boost signal...
A turn table produces sound voltage in the millivolt range. If you have it connected to a receiver that has a phono input and the turn table is pre-amplified, you are overdriving the receiver and it is clipping the audio and making it sound bad.
Jan 17, 2015 | Yamaha RX-V592 5.1 Channels Receiver
What does HDMI 1,2,3, VGA, PC AUDIO, and USB work? I have a Element ELEFW504A.
You h.ave listed the various inputs for your TV. Get a manual and read it
Jan 07, 2015 | Televison & Video
My 50 inch element wont work when i plug up my cablevision but it will work when i use a antennae
Use AVI in mode. Your TV input selection is not set in Audio video mode. From option menu or input button on remote select AVI input.
Dec 16, 2014 | Element Televison & Video
My element electronics tv says no signal
Two things to try:
1. Connect a DVD or something else to one of the rear audio/video inputs to see if set works that way.
2. Check to make sure set in menu is set to tuner and cable---if the tuner in the set is bad a cable box with audio/video outs on the back can be hooked to one of the rear audio/video inputs and will bypass the tv tuner--you will stay that input to watch TV and change channels with the box----
The cost of renting a box is minor compared to having to replace the tuner in the set.
Mar 24, 2012 | Element Electronics Televison & Video
Replaced therostate dyer still dose not heat up
check your heating element for being open,then the hi-limit switch, then carefully inspect all electrical connections around the element case for burns and brittle wiring, also chk neutral at the terminal block on input power and at element case for a solid connection
Oct 15, 2009 | Dryers
Dropped the mic.
I would imagine the mic element broke. To test, remove from the case and without touching anything else, touch (using a small screwdriver if need be) the solder connections on the wires for the mic element (while system is up). Hum? Yes? bad mic element. No? Problem with electronics. Look for broken wires also.
The receiver shows signal so RF is ok. You have a problem with the audio section.
Apr 28, 2009 | Audio Players & Recorders
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Kenwood VR-6070 Receiver Logo
70 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
