Question about Spinmaster Air Hogs RC Reflex Micro Helicopter
Will not lift off surface - Spinmaster Air Hogs RC Reflex Micro Helicopter
    Genius:
  • 1,126 Answers
The battery is to weak and no fast enough to get it off the ground.
Posted on Jan 02, 2011
I am having intermitent problems. If hot water spills onto the surface of my ceran surface, all the controls start flashing. The same thing happens every now and then when I just wipe the surface wi
Lift the top of your stove, then look for a connector or plug, wire that has pushed up near or against the stove top. Where the wires connect to the burners one or more may be loose an needs tightening.
Mar 26, 2014 | Whirlpool Cooktops
How to clean ipad screen
best is a microfiber towel which you can buy in many shops and can also be cut in small pieces.
  • microfibers lift dust and oils from delicate surfaces without the use of chemicals
  • Ideal for eyeglass lenses, camera lenses, displays, binoculars, microscopes and other delicate surfaces
  • Non-scratching, non-linting
  • Dirt and particles are trapped within knitted tufts of the fibers
  • Ribbon-shaped fibers lift dirt and grease instead of rolling over it
clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-0.jpg clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-2.jpg clean-ipad-screen-megbyxdvyw15034h4mjt4m35-4-5.jpg
Jan 15, 2014 | Apple iPad Tablets & eReaders
Reattach the base on insignia tv
Place the TV face down on a soft surface. Position the base for installation of attaching screws and install screws. Lift the TV off of the soft surface and place in desired location
Feb 22, 2013 | Insignia LCDTV26 26 in. Television
Can anyone explain to me what an air caster is?
An air caster is a pneumatic lifting device used to move heavy loads on flat, non-porous surfaces. its like a hovercraft, it lifts something about 1 mm off the ground with compressed air
Jan 30, 2013 | Air Tools & Compressors
My range has a solid burner set into the top without any obvious way to remove it from the top. How do I access the connections or remove the burner from the range?
There should be 2 release "tabs" between the top surface piece and the main range... e.g. the "slot" in the front of the range.
You'll need to lift slightly on the top surface while pressing these tabs with a thin utensil - like a butter knife or paint scrapper. Be careful to not scratch the paint.
The tabs are located on the front left and right.
In some cases, you can slightly lift the top panel to get a better view of the tabs with a flashlight.
Then, the top should lift up, similar to the hood of a car.
Once inside, it's pretty easy to work on the connections, burners, etc.
Feb 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Where do you place batteries in a wireless mini mouse
I have seen a couple of ways to get at the batteries on a wireless mouse. One is to look at the bottom to find a standard battery cover complete with a little finger slot that allows the plate to be lifted off from the bottom surface of the mouse.
The other is a sliding latch at the back of the bottom surface of the mouse body that releases the battery flap which then lifts upward. The flap is the backside skin of the top of the mouse.
Feb 08, 2011 | Dell U0636 Mouse
3.0 Peak HP 16'/41 cm remington
You might actually have the chain too tight. With the saw off you should be able to lift the chain until the gear tooth (tooth on inside of chain) almost lifts out of the chain bar.
I've never used an electric chain saw but if it has a chain oiler you should also check your chain oiler to make sure you're getting enough oil on the chain, if you run the saw with the chain aim at a clean surface you should see oil on the surface almost immediately.
May 26, 2010 | Remington Electric Chain Saw
The lever to adjust bowl height will not move.
most of the times it is because of build up between lift handle and pedestle case use wd-40 and even some heat from a torch to help loosen up stuck handle. also wd-40 the ways on the mixer ped. where the bowl yoke is
Dec 15, 2009 | Hobart A200 Stand Mixer
Hayward phantom will not float fully to the surface
If it has skimmed the top of the pool before try rearranging sections of the hose and make sure all sections of hose can rotate freely.
Apr 04, 2009 | Hayward Phantom Pool Cleaner Complete with...
Hayward Phantom pool cleaner-up/both/down switch replacement
There are 5 screws on the bottom, remove them and hold the cleaner together while turning it right side up. Lift off the top cover (watch the styrofoam inserts that go behind the back wheels), sometimes they fall out when the cover is removed but they're easy to put back in place. This will give you access to both the switch and the round gear box. Lift both out then put the switch on and lower the gear box back into place.
Mar 19, 2009 | Phantom Pool & Spa
Spinmaster Air Hogs RC Reflex Micro Helicopter Logo
88 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
