Question about Radio Shack Pro-95 Handheld Scanner
I HAVE A PRO-95 SCANNER AND A NEW COMPUTER WITHOUT A SERIAL PORT ON THE PC.I HAVE THE SERIAL JACK CABLE . ARE THEIR ANY UBS ADAPTER THAT WILL WORK ON THE SERIAL JACK CABLE. THANKS.
    President:
  • 2,761 Answers
You can find a variety of serial to USB adapter cables on eBay.
Bill B.
Listening in since the 60's
Posted on Dec 31, 2010
My computer that has PSW2.0 crashed. It had Windows XP. I have a new HP computer with Windows 7. What do I have to do to make it work on my new computer?
From Singerco.com FAQs: Q. My computer only has USB ports. Can you recommend a Serial (nine pin) to USB converter cable that will work with the Professional Sew Ware™ 2.00a? A. We have found that the PSW works best on newer computers when the USB serial adapter cable has not only compatible drivers for the Windows operating system but also a FTDI chip. We have found this FTDI chip in the cable which is listed below:
CUSB-232A available from Computerplug.com and Cablesalesusa.com.
Any USB to serial adapter with an FTDI chip will work. These cables will work for Windows XP, VISTA, and 7.
Sep 23, 2010 | Singer Professional Sew Ware Options 2.0...
I cant figure out how to connect my jornada to my pc.. can you help?
Are you connecting from dock to USB on computer, or serial to USB via a USB-serial adapter? UBS-serial adapters are notorious for not recognizing attached serial hardware. What kind of errors are the Jornada and the computer throwing? Can you give any specific error numbers?
If you are connecting using the serial cable to a serial port on your computer you need to make sure that the Jornada is trying to connect to the correct COM port (and that the computer is allowing connections through the correct COM port). Do this by:
1. Open Device Manager (R-Click on My Computer - Properties - Hardware - Device Manager)
2. Expand the "Ports (COM)" plus sign
3. Beside each COM port's name it will say (COM#) - the # tells you which port the COM is
4. Go into ActiveSync and open Connection Settings (in the File menu in ActiveSync 4.5 - the latest)
5. Make sure all the check boxes are checked and that the correct number COM port is selected in the drop down menu under "Allow connections to one of the following:"
6. Connect your Jornada via the serial cable, make sure the Jornada is on and connected to power cable (I have had more success with the power on - may or may not affect your problem)
7. Click the "Connect..." button in ActiveSync. The Jornada should be detected.
If your computer has an infrared port you could try that, I have had a lot of success with infrared connections with my Jornada. Also, try installing ActiveSync on another computer that has a serial port and try connecting the Jornada to that computer. It may be a problem with your computer.
An older version of ActiveSync should not make a difference. The facilities are the same, just slightly rearranged.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 01, 2010 | Computers & Internet
My older hi-pro box will not work with my serial to USB adapter. It keeps saying it cannot find it on com 1,2,3,4. In the device settings it says the hipro is on port 2 and the serial/USB bridge is on port...
I just set up a serial Hi-Pro box for one of my customers on their new laptop. According to Beltone, the only usb adapter that will work with the Hi-Pro (or at least the only one they have gotten to work) is a Belkin F5U409. I know some usb serial adapters don't use true serial communications if that makes any sense, so there isn't really a baud rate. They kind of just send out the communication in bursts...
In any case, ive only tried with the belkin adapter and that worked fine with no problems. The other point here is that your Hi-Pro and Adapter are on different com ports... This is odd, the hi-pro should be on the serial adpater's com port. Also the software i was using - Noah, with a beltone module for programming hearing aids.. only looked on com ports 1-3. The computer put the serial adapter on com 8 - which would not do. I checked for available com ports and saw that 2 was unused. I set the adapter to 2 and was able to set up the program normally.
I did this on Windows 7 Professional 32 Bit. The procedure for selecting the com port is the same on earlier versions of windows.
First, open device manager, open the list titled "Ports (COM and LPT)". You should see your serial adapter in there. Double click it. In the window that opens click the "ports" tab, and hit the button labeled "Advanced" In the window that opens there will be a drop down list to select a com port. Select the desired com port and hit ok. That should fix it.
Jul 12, 2009 | Uniden Unipro PC100
PSC Duet RS-232 Handheld - help needed :(
hello The cable has taken power?
it is important to the power adapter and cable PSC.
fai photos to the cable and sends me. Then explain how to connect to xp.
hello Roberto
Jun 04, 2008 | PSC Duet RS-232 Handheld Barcode Scanner
Download of Pictures to a computer without a serial port
i want to down load video from canon camcoder dc220 to pc windows xp i down canon software to pc
Mar 12, 2008 | Sony Handycam DCR-TRV265E Digital...
Hp jornada 720 handheld pc
Try a older version of active sync. 3.0 or 3.1
heres 3.1
http://www.tucows.com/preview/32548
Feb 17, 2008 | HP Jornada 720 Pocket PC
Radio shack Pro-433
Look at www.radioreference.com This is the most complete scanner site on the web. Just register and then search the forums for what you need.
Jan 18, 2008 | Radio Communications
how do i download pictures from my motarola v3 to my pc.(windows vista) using a USB cable.
Jan 11, 2008 | Philips ESP2 Digital Camera
Radio Shack Pro-95 Handheld Scanner Logo
78 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
