Question about Dell Dimension 9100 PC Desktop
Computer won't power up. opened case to replace hard drive. After replacing the hard drive the computer would not power up. Reinstalled the old hard drive and still the computer won't start up.
    Problem Solver:
  • 5 Answers
Check your connection between the power supply and the motherboard. Is it possible that your power supply was getting weak instead of the hard drive you replaced? First check the power connection and then try another power supply. If a different power supply boots the computer then you know that it may not have been a problem with your hard drive. You didn't say why you replaced the hard drive.
Posted on Jun 23, 2011
Replace hard drive motherboard
Before you start replacing drive you need to ask yourself if you are trying to replace a bad hard drive and just want to start with a clean install of the O.S. OR are you replacing your hard drive with a bigger one and wish to keep your installed programs, data and documents. If you want to keep your data and documents you need to know how to save the Files and folders on your computer to a CD, DVD or a USB hard drive. Just replacing the hardware involves unplugging all cables from computer after shutting it down. Then opening the case and unplugging the cables from the hard drive and then remove the screw(s) retaining the hard drive. Remove the old hard drive from the case and replace it with the new one, replace screws and plug cables back up watching that that the connectors are correctly aligned with the key(s) on the hard drive's sockets. Replacing the Hard drive also involves installing the O.S. and all your programs and applications on the new hard drive. You can find a lot of information in the internet about this.
Oct 21, 2013 | Gateway SX2855 Case
Can I get a new mother board for my HP Pavilion Slimline s5120f computer, so I can reinstall my old hard drive with out losing my software.
Yes you can install a hard drive on any computer as long as it has the same power and data connections and plugs.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards If your current hard drive is on the fritz, or you have an older drive with data you need to retrieve, it's a fairly short process to swap out an existing drive with an old unit lying around the house. To replace the hard drive you need to be comfortable taking apart your computer and working inside its case. The hard drive is located in the series of metal drive bays located underneath the computer's side access panel.
Shut down your computer's operating system. Disconnect the power cable from the back of the computer case and unplug any other cables, such as for the monitor and mouse. Set the computer case gently on its side on a stable work area such as a desk or table. Check the far left end of the case to determine if the side access panel uses screws or a release button. Remove the two screws with a Phillips screwdriver, if they are present. Instead press in the plastic release button, if one is present. Push down the side panel and slide it off the computer. With some models you may need to instead lift the panel to the right until it locks at 90 degrees. Check the metal drive bays near the front end of the case and locate the one containing the rectangular metal hard drive. Unplug the data cable and the power cable from the ports on the back end of the hard drive. Remove the screws holding the hard drive to the metal drive bay. Set the screws aside in a container so they don't become lost. Grip the back of the current hard drive and slide it out of the drive bay. Slide the old hard drive you want to use into the drive bay, and ensure the power and data cable ports are facing into the computer's case. Plug the power and data cables you removed earlier into the corresponding ports on the back end of the old hard drive. Replace the screws removed earlier to hold the old hard drive to the metal drive bay. Replace the computer's side access panel and tighten the screws in place, if it used them. Reconnect the computer's power cable and the other cables you removed earlier. Press the computer's power button. Hope this helps.
b>
Dec 26, 2012 | Computers & Internet
How to change a pc hardrive
It is actually pretty simple to do. First of all, make sure you have a backup.
1. Open you computer case. You will likely have to open both sides, unless you have a hard drive enclosure, so check your computer manual on how to do so.2. Pull out the power and SATA cables (will be red and thin). You will need them when you install the new hard drive.3. Unscrew the hard drive. If it is in a hard drive enclosure, it will likely be held by thumbscrews. Unscrew the thumbscrews holding the enclosure to the case and then unscrew the hard drive.4. Place the new hard drive into the computer or enclosure and screw in. If in an enclosure, screw the drive into that and then enclosure back into the computer.5. Plug in the cables that you took out of the old hard drive.6. Close the case, install operating system if it was replacing the hard drive that had it, and you should be good to go.
This video should help if you are confused:
Here is a video that will show you how to replace your hard drive:
http://www.youtube.com/watch?v=xN59W-56p3I
Mar 28, 2012 | HP Computers & Internet
Hard drive won"t come on
Does it say it cannot locate the hard drive? Try turn the computer completely off, unplugging the power to it. Then, ground yourself by touching the PC case, and open the PC up. Once you do that, unplug the hard drive,then reconnect it and make sure its completely pushed in. Then put the case back on and power plugged back in and turn your computer on.
Jul 18, 2011 | Computers & Internet
Computer does not power up.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 21, 2011 | Antec SL350 (smartpower sl350) 350-Watt...
Computer is not booting up. Usual blue light over power switch is red.
hope this will help
don
Feb 15, 2011 | Thermaltake Wing RS 101 Case + 430W PSU:...
How do you replace the harddrive
replacing a hard drive is very easy all you need to do is open your computer case and swap out the old one for a new one you just unplug the 2 wires from the old one and plug them into the new one. Attached I have added a link to a how to guide.
http://www.ehow.com/how_4424308_replace-hard-drive-computer.html
I hope this helped
Thank you,
Norse
May 18, 2010 | Gateway 300 C PC Desktop
Computer noise
More likely one of the fans, but could be the hard drive. Open the case and listen. Fan on power supply, fan on processor, or hard drive are the most likely sources of the noise. Processor fans and power supplies are both cheap and easy to replace. Hard drive is a bit more expensive and you must back it up (which you already regularly do, right?) if you want to keep your data.
Apr 24, 2009 | E-Machines T3112 (RBT3112) PC Desktop
No monitor display
this site
http://www.ultimatebootcd.com/download.html
is a link to Ultimate Boot Cd
this is a bin file to be burned as boot Cd
it contains a various tools including hardware check (google it!)
hope it helps
feed back
Apr 05, 2009 | HP Computers & Internet
I had an old pc case with everything but a hard drive so I took my old hard drive out and placed it in the other hard rive less pc. Now it is saying the hard drive can not be found , how do I get my...
make sure that the hard drive is on one cable the ide and that the power is run to it, there is also a jumper setting on the back of the hard drive, you want this little jumper to be on the "master" setting. lastly resetting the bios to defaults will ensure that bios will detect the old hard drive. it will prompt you what key to press to enter bios. generally the key will be F2 F1 delete or TAB try pressing each of these before the computer beeps. in all reality there is much more to replacing a hard drive then plugging it in windows will need to be reinstalled as well as the drivers will be designed to run off the other computer
Jul 02, 2008 | Gateway Computers & Internet
Dell Dimension 9100 PC Desktop Logo
90 people viewed this question
Alun Cox
