Question about Amana AER5725QA Electric Kitchen Range
Hello, I lost the manual but want to clean an Amana, gas, self cleaning oven in my range. The range is about 15 yrs old. It has a lever on top of the oven door & two black knobs on the panel. Both knobs have a clean function printed along with bake, broil etc. Thanks, Cynthia Freeston
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
fridgetech
  • 473 Answers
SOURCE: amana range will heatup then turn it's self off
F3 F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Oven temp. sensor needs to be replaced. You should be able to look at diagrams with the model # for part location @ http://www3.sears.com/ or http://www.appliancepartspros.com/. The sensor looks like a rod about 4-6 inches long and mounted to the back wall inside the oven. Some can be pulled out from insided the oven by taking out the two screws. If no screws then you will have to pull the oven out and remove from the back.
Posted on Nov 07, 2007
SOURCE: Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
Posted on Dec 01, 2008
SOURCE: oven bake does not work properly
check the selector swich and thermostat.
Posted on Dec 07, 2008
fixyourboard
  • 310 Answers
SOURCE: Amana Range, AER5515QAW
could be a bad bake element, bad temperature sensor, or control board problem
what does the oven readout display for temperature? if the readout agrees with the actual oven temperature ... it is probably the element
if the oven readout displays a much higher temperature it may be the temperature sensor (the probe in the oven cavity) or the control board
the temperature sensor can be tested by measuring its resistance with power off and unplugged from the control board, should be about 1100 ohms at 75F
If the sensor is good, then it is probably the control board ... in which case we can repair it for you at www.fixyourboard.com
Posted on Jul 21, 2009
Hello - I am trying to use the clean oven option - the digital screen is displaying a F- 9 with a continuous beep. What should I do?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 22, 2010 | Amana ARGS7650SS Gas Kitchen Range
I LOST MY INSTRUCTIONS ON HOW TO START TO CLEAN MY SELF CLEANING OVEN pLEASE HELP IT IS A AMANA
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 12, 2010 | Amana ARGS7650SS Gas Kitchen Range
Oven cleaning
Before you use that feature read this tip that I wrote about that...
heatman101
Mar 31, 2010 | Amana ARGS7650SS Gas Kitchen Range
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
Amana range ARG7800E Oven, Broiler and Self Clean will not ignite
heatman101
tti
Apr 07, 2009 | Amana ARGS7650SS Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Apr 07, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana AER5725QA Electric Kitchen Range Logo
42 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
