Question about Hasbro Nerf N-strike Longstrike Cs-6 2010 Refreshed
Trigger is stuck in my nerf longstrike - Hasbro Nerf N-strike Longstrike Cs-6 2010 Refreshed
My NERF gun broke.
Take it back to where you bought it. It shouldnt do that, it sounds faulty to me. I am sure they will replace a faulty item.
Feb 26, 2014 | Hasbro Nerf N-strike Longstrike Cs-6 2010...
Nerf gun lazer tag
i have the same problem and i noticed that when i go outdoor, the trigger will work again. i think it is something about interference by some sort of radiofrequenceis.
Nov 08, 2013 | Toys
Nerf pallets
Hehe, a little inter office competition. I would recommend you google your respective nerf gun with the question including AMMO for nerf gun. You'd be surprised. You can actually find it in BULK, so if you keep this to yourself, you can outlast your competitors..
Mar 22, 2013 | Toys
How do I unjam a double cocked nerf diatron
1. Make sure that there are two disks loaded in the launcher. They must be pressing against the pressure switch at the top of the chamber. 2. Use a screwdriver to push in the T-shaped switch that would normally be triggered when the priming lever is closed. When both switches are activated, the trigger should be unlocked, allowing you to fire and to release the priming lever.
Feb 15, 2013 | Toys
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
Feb 27, 2011 | Hasbro Nerf Dart Tag Strike Fire Two Pack
I **** it back and then hit the trigger and it won't fire... it rotates the barrel and after about a minute or so of pulling the trigger rapidly it will fire. i want to be able to shoot normally and i did...
The factory must have left out a certain spring I could only explain to you if you've modded it.
Well, I'm going to explain anyway-
When you pull the trigger there is a mechanism is triggers that releases the plunger system, therefore compressing the air and firing the dart out of the turret. The factory (as I said before) left out the spring that makes the part move up or down as the trigger is operated, therefore making the gun malfunction.
My best suggestion- get a spring and add it in (if this is the case). Open up the shells/casing of the gun by unscrewing it apart and find the orange part next to the trigger.
Please email me at dluzzio@gmail.com a picture of the inside of your gun so I can analyze it.
If all else fails, take it back to the store.
Dec 30, 2010 | Nerf Maverick Blaster
My kid opened the Nerf N-strike Recon CS-6, loaded darts in the clip, shot it a few rounds, and now, somehow, the cocking mechanism is stuck in the middle position, and so is the trigger (like...
Take the rear bolt cover off ( 2 screws) . Reach inside with your finger and try spinning the spring. For some reason the spring will eventually move to a position that when compacted will bind with the bolt pass through hole.
Dec 25, 2010 | Nerf N-Strike Longshot CS-6 Blaster
How do you turn on the light
to activate the light you need to insert two AA batteries into the handle at the bottom.When you have done that hold the trigger without loading any darts and it will light up.
Jun 26, 2010 | Nerf Nite Finder
Where is the battery compartment for a nerf havok nstrike fire ebf-25.
There is a gray battery cover a little bit above the trigger. You will see a screw hole
Jan 02, 2010 | Nerf Secret Strike As 1
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Hasbro Nerf N-strike Longstrike Cs-6 2010 Refreshed Logo
177 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
