Question about Jenn-Air Kitchen Ranges
I have a Jenn air wall oven 800181 and need to know how to use the clean feature
  • 26 Answers
SOURCE: Jenn Air auto clean oven
after it cools down move the lever to the left
Posted on Jan 09, 2008
SOURCE: Jenn-Aire locked tight!
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Posted on Jan 20, 2008
SOURCE: Selfcleaning Jenn-Air electric oven
door lock switch must activate for clean to work. door may not be shut completely.
Posted on Apr 10, 2008
  • 15 Answers
SOURCE: Oven won't lock and self clean.
Shut off the oven for at least a minute and turn it on, set the clock, and it worked. I had tried a short power cycle before and it didn't fix it. The extended power cycle did the trick.
Posted on May 02, 2008
SOURCE: jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Posted on Feb 28, 2009
What size circuit breaker is needed for a jenn-air wall oven 240 volt 3 wire #6wire model 800181
most ovens require a 30 amp circuit breaker ( now RCD unit)
talk with an electrician as to the requirement
Aug 17, 2016 | Jenn-Air Ovens
Jenn-Air W241-C wall oven
Unless you can find one in a used oven, I don't know. Jenn air website says they are discontinued and offers no substitute part.
Jul 17, 2014 | Jenn-Air Ovens
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
Dec 15, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
We do not have a manual for the jenn air wall oven JJW8530BAB. we just hant to run the clean cycle but can't figure it out. anyone know how to set it to clean? sigmawolf
Actually I did not solve the problem as I'm just looking for a manual for the wall oven so I can set the clean cycle. I just can't see joining a service for just one manual.
Thanks,
Sigmawolf
Dec 16, 2009 | Jenn-Air JJW8530C Expressions Collection...
I have a self-cleaning wall oven model w2750 . When I put the process for cleaning to operate the Clean light does not go on .... what could be wrong????
do not know how to clean wall unit i have a jenn air the # arejjw9530aas. the serial are 10208841wv . please help this is a rental house and i would like to give it back clean . thank you .
Sep 17, 2009 | Jenn-Air Ovens
Jenn-air microwave JMC 7000 ADB has no power
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Kitchen Ranges Logo
89 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
