Question about Remote Talking Alarm System 2030mc
My husband recently bought the Bulldog Talking Alarm, model 2030. He followed the directions and the alarm said "thank you" after being successfully installed, but after that it wont arm an the L.E.D light wont flash. What did he do wrong? Thank you for helping!
  • 733 Answers
SOURCE: my bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Posted on Sep 09, 2009
Testimonial: "Wow thanks, I searched for an hour and never found anything this is great thanks again "
  • 33 Answers
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Posted on Mar 02, 2009
SOURCE: Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Posted on Nov 14, 2009
SOURCE: Bulldog remote start brain module acting crazy!, turns alarm on!
I have installed 4 deluxe 200s ( 2 on my vehicles and one on each of my parents) and I seem to have problems with the remotes dying but no other problems. I had to buy another unit just to get the remote so now I have an extra deluxe brain brain. If you are interested email me kbirdjr@sbcglobal.net If you decide to get a different unit I might be interested in buying your remote.
Posted on Dec 14, 2009
iadame
  • 676 Answers
SOURCE: how to hook up bulldog
Hello my name is Israel and I will be glad to help you out. This alarm system uses a drop in voltage sensor to work. First mount the siren on a firm ground metal of the vehicle. Be sure that the base is mounted on metal and not plastic. Then, the best way for the system to work is to run the wire into the vehicle cab and connet the one wire to the positive side of either the dome light fuse or dome light wire. This will help in it "catching" voltage drops when the lights go on. Good Luck.
Posted on Feb 15, 2011
How to hook up bulldog 1-wire alarm
Feb 15, 2011 | Bulldog& Remote Alarm System With 1-wire...
No mauel for bulldog remote
You will want to look under your dash and find the model number of the Bulldog unit you have. Then check out http://www.bulldogsecurity.com/ for the manual and a troubleshooting guide.
Feb 12, 2010 | Basic Remote Vehicle Alarm System
Someone programmed their remote into my Bulldog 2010 alarm brain and is deactivating my alarm and then vandalizing my car. How do I get rid of their programming instructions and neutralize their remote?
Your model will only keep 4 remotes in memory, so in order to deactivate there remote, you need to have your remote programmed 4 times into your unit
Dec 17, 2009 | Basic Remote Vehicle Alarm System
My bulldog Model 2010 Alarm is too sensitive and
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Set up
Turn the valet switch on, start the car with your key wait 15 sec, press the * star button 2 times with the car running, it should beep and program if not turn valet switch the other way and try again, if still nothing post me back and we will go from there
Jan 15, 2009 | Bulldog& Remote Alarm System With 1-wire...
Where may I obtain a replacement remote and directions for Bull
go to www.BulldogSecurity.com and do a little looking. I had the Same Problem with Mine and got mine through their Website. They will tell you also how to Program the New Remote to match your Starter. Let me Know how it Goes!
Jan 02, 2009 | Bulldog& Remote Alarm System With 1-wire...
Remote Talking Alarm System 2030mc Logo
191 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
