Question about Mackie 1604 Vlz3 16 Channel Mixer
Someone spilt half a pint of lager over my Mackie 1604 Vlz3. The desk operated for an hour after but gave some noise so I switched it off. I cleaned off all the surface fluid but some of the knobs, faders and buttons are sticking. I opened up all the screws on the desk but the board inside is fixed to the front metal side with either allen bolts or rivets, can you confirm which please? How will I open the board away and fix back, and what product will I use to clean it?
  • 4,234 Answers
These units are not the easiest to open up without damage. The lager has likely evaporated and left behind some residue. Yes the pc board it attached by allen screws. Each control must be removed as well. This unit requires a complete clean with an electronics wash. It is possible that there is some corrosion as well. Please have this cleaned professionally and checked. It is in your best interest in the long run.
Dan
Posted on Dec 30, 2010
How to connect power subwoofer mackie
Take the mono output from the desk to the powered subwoofer, it should have it's own crossover/low pass filter built in.
Jan 30, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Some of my channels have stopped working 4-5-6-13-14-15-16 mackie 1604 vlz pro
If you havent ground looped the chanels. Most of the time the chanels need to be cleaned.
Dec 01, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Please i need a manual for mackie 1604 viz3 thank you
You can download the manual here: http://www.mackie.com/pdf/archive/cr1604_om.pdf
If you have specific questions please update this and I'll try to get you an answer.
Dan
Oct 28, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Where can we find replacement faders for mackie 1604
See the link below for contacts either locally to you are from Mackie support directly. These guys are extremely helpful. Please have the serial number of the unit with you when you contact them. That will insure that the correct parts are ordered.
DAn
Link: http://www.mackie.com/support/
Aug 24, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 VLZ3 Issue.
Hi kielhunt
It sounds like power supply issues.
You may have bad capacitors and/or bad regulators.
If you have a multimeter you can get in there and check the dc voltages for ripple(ac voltage mixed with dc) or over/under voltages along the +/- 15volts lines.
Good luck
Jan 20, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
Apr 04, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 Vlz3 16 Channel Mixer Logo
55 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Are you a Mackie Music Expert? Answer questions, earn points and help others
