Question about Olympus FE-190 Digital Camera
Olympus FE-190 The battery is charged, but it won't turn on completey. The lens comes out and right back in. The display window will not light up.
  • 5 more comments
  • Anna35 Jul 26, 2008
    I have the same problem.
  • Anonymous Aug 26, 2008
    The lens just cycles out and in a few times then turns off. No display. Tried recharging, pulling out memory card and battery, no change.
  • incogneeto Aug 31, 2008
    I have exactly the same problem. There is plenty of power in the battery, and the case seems tight and in good condition. Any other suggestions please?
  • Anonymous Oct 05, 2008
  • rigosuave_19 Oct 15, 2008
    when I push the power button , the camera does not work, however if push and hold the power button the camera start to work. and some times it turned off by itself.
  • krasimir81 Oct 23, 2008
    I have the same problem. Usualy after power up in AUTO I do not get picture on the screen. After I change to other mode and back to AUTO I get A picture but not in focus. I am elctronics enfineer and expert in enbaded systems. Ibelieve thet is a software bug and Olimpus shuld take responsibility.
  • sechack Oct 31, 2008
    Same problem. Weird buzzing noise when turned on. Lens goes in and out a couple of times. No display on the lcd unless you flip from auto and the other modes. When it does work the camera does not focus. Seems the auto focus is messed up.
On the right side of the camera where the memory card goes in thats where it is usally loose it it does that. try not to touch the part that slides out when you take the pictures or turn it on and it will be back to normal.
Posted on Aug 30, 2008
The battery is charged, but it won't turn on completey. The lens comes out and right back in. The display window will not light up. sometimes the screen lights up for view finding and goes off when i release the power button
Posted on Oct 18, 2008
When I press the power button for my Olympus FE-190 to turn the camera on nothing happens. I haven't used it for a while so I initially thought that the battery might not have any charge. When I put the...
Most likely the battery has been depleted. When you are not using you camera you should always recharge the batteries every now and then. This ensures that they will last longer. Try buying a new battery for your camera.
Feb 28, 2010 | Olympus FE-190 Digital Camera
Olympus FE-190.... video is very dark. cant
go to its settings and fix the lighting for the lcd pannel. then you will be able to see the flash yes or no click yes..
Jan 26, 2010 | Olympus FE-190 Digital Camera
Olympus fe-190 camera, keep getting message lens error, restart camera, also monitor is grainy and fuzzy, unable to take crisp, clear pictures, and make strange sound...
The problem you are describing is a problem with a sensor in the lens assembly. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $80.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 08, 2009 | Olympus FE-190 Digital Camera
Olympus FE-190 lense
If the internal lens barrel gets knocked out of alignment it will cause that condition. If the camera senses that the lens is not in the proper position or not moving, it will turn back off rather than cause more damage. Pushing on the lens barrel to try to fix it will usually cause more problems than it already has. It has to be disassembled to be repaired.
at this point you may also want to check on your warranty status.
Aug 05, 2008 | Olympus FE-190 Digital Camera
My camera isnt working
if the picture turns all white, then you might have a problem with the screen.
-or your're just aiming it at a bright object. (try covering the lens with your hand- dont actually touch it, just block out the light and if the screen goes dark then its still working)
if some sand or grit got inside your camera, then you have a serious problem, as sand is very abrasive,and could damage the internal mechnisims.
you should seek professional help on getting the inside cleaned out.
May 03, 2008 | Olympus FE-190 Digital Camera
Olympus FE-190 Digital Camera Logo
226 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
