Question about KitchenAid KBLA20ERSS Stainless Steel Bottom Freezer Refrigerator
Need a new Deli-Drawer unit. Plastic knob came off of cover for Deli Drawer
SOURCE: deli drawer
Dear Master Tech: The model number is GLRT13TEB3. The problem is every time you try to open the deli drawer it falls straight down.
It is as if the tracks to hold it are too far apart? Also the tracks are part of the glass shelf.
Any help with this annoying problem would be much appreciated.
Thank-you, Nanc T.
Posted on Feb 17, 2008
SOURCE: I would like to order
repairclinic.com
Posted on Aug 02, 2008
SOURCE: need top shelf for admiral refrigerator
Click on this link to see if they have what you were looking for.
http://www.repairclinic.com/Appliance-Parts?s=t-HMG211380-%3d%3dc270
Your refrigerator stopped being built more than 6 years ago, so some items are no longer available.
Posted on May 02, 2009
  • 864 Answers
SOURCE: Cracked fronts of drawers GE profile PSS26LSRCSS
Try the GE website or these:
  1. GE Fridge Parts Onlinewww.AppliancePartsPros.com/Parts      Good prices on GE fridge parts. Same day shipping. Order now!
  2. Ge Profile Refrigerator Partswww.RepairClinic.com      850,000 parts, 93,000 photos. Call center, same day shipping
  3. GE Refrigerator Partswww.pcappliancerepair.com      OEM source of GE refrigerator parts Online or toll free 1-877-922-2880
Posted on May 29, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE Profile side by side...water collects under the
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 27, 2009
Will the deli drawer work properly without the glass door/lid? The pin broke off the right side and can't be fixed ... plastic broke off the actual drawer roller on the right. Cheap plastic ... disapp
Call in a repair man, it shouldn't cost that much. Yes, your food will be effected without that plastic door, as the drawer has controls and cold settings just for deli items. You need a special glue for cold. I'd call in a repair man, or order a new drawer replacement from the manufacturer.
Dec 01, 2014 | Maytag Refrigerators
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
Need to remove deli drawer
Hi there, it should pull straight out, you might need to get someone with a bit of strength to help you.
If I could I would duck over in a jippy !!
Jan 07, 2014 | KitchenAid Refrigerators
Deli drawer hinge broke
Try searching w/ Google on the brand and model no.
Here's one possibility: Parts
Sep 01, 2012 | Whirlpool GI6FDRXXY
Kenmore Refrigerator 596.73503200 deli drawer cover hinge pin on right side broke off. Part #?
I would direct you to this link to find the part number you're looking for. I do not have one of these units to look at so am unsure which specific piece you'll need to replace.
Model 59673503200 KENMORE ELITE KENMORE REFRIGERATOR Parts
Nov 03, 2017 | Refrigerators
I purchased whirlpool GX5FHTXVA and there is a divider piece of plastic taped to the bottom of deli drawer, I have no idea where it goes. It is not in the manuel.
The wider end of the piece can be hooked anywhere on the back of the deli drawer. Keep the piece bent when you install it or it will scratch the glass on the front of the drawer. Also, make sure the tip of the smaller end is touching the bottom of the drawer before straightening the divider._1165.jpg
Apr 17, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
PURCHASED FRIDGE OFF FLOOR AT SEARS; THERE IS A DIVIDER LIKE PIECE OF PLASTIC TAPED IN BOTTOM OF HANGING DELI DRAWER. I HAVE DOWNLOADED MANUEL; BUT THERE IS NO INFO ON HOW TO PLACE ITEM.
the plastic tape is removed entirely from the unit is the first step check also on these manuals to see if they tell which drawer your trying to install there at the bottom of the link heres the link http://www.big-georges.com/GX5FHTXVA.aspx please message me back if you have any further questions and remember to rank if this opinion has helped in your appliance situation
Thanks again
Rick
Nov 07, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Need top shelf for admiral refrigerator
May 02, 2009 | Refrigerators
KitchenAid KBLA20ERSS Stainless Steel Bottom Freezer Refrigerator Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
