Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
Hello, I have a side by side Whirpool model #ed5shaxmt10. I recently had water connected to the fridge 2 weeks ago by a plumber. It worked great until a couple days ago. It quit dispensing water. I ordered a new filter that should arrive on Jan. 8 hoping it is just a plugged filter but wanted to check with you to see if there is anything else you would suggest checking. My other thought is if the water line could freeze? Is the water that comes out due to the house water pressure or is there a motor to boost the flow as I could here a slight hum when it was dispensing and of course now that it has quit dispensing nothing happens. Thanks in advance for any advise. Bob Belyea
SOURCE: Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Posted on Jan 04, 2008
SOURCE: Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Posted on Feb 03, 2008
  • 3422 Answers
Try defrosting it, if this doen't work then do the following and ur problem will be solved..
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Goodluck,
Please don't forget to rate me as fixya..
  • 16 Answers
SOURCE: The water dispenser on my
did u check the value from your water line? the value could be shut. If the value is on...did you connect it correctly to your water system? let me know!
Posted on Jun 16, 2008
vanni7
  • 163 Answers
SOURCE: Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Posted on Jan 03, 2009
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
Kitchenaid superba making noise
Check the fan on the back and blow air through it to clear any dust accumulation.
May 04, 2017 | KitchenAid Superba KSRG25FK Side by Side...
The cold water dispenser in my whirlpool refrigerator stopped dispensing water about 2 years ago. Recently it just started dispensing water and does not shut of. I had to close the valve to the water and...
Hi copy;
You may like to try the Water Valve (Solenoid) sounds like it may had stuck once now has become free and stayed open allowing too continually flow. It is behind fridge where the mains water is connected into fridge... Cheers
Mar 16, 2010 | Whirlpool GS5SHAXN Side by Side...
Water dispenses very slowly on Fridge
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The coil of tubing is normal so you can move the fridge out from the wall without damaging anything.
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 14, 2010 | Refrigerators
Bad tasting water
Do not use a steel or plastic braided supply line. They make the ice taste bad.
Dec 29, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
WATER DRIPPING FROM DISPENSER IN DOOR. GE Model TFX20JRBG WH
You are correct. this is actually a faulty inlet valve(dual) assembly. replacing this faulty valve will fix this issue.
Jun 19, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice Maker not making ice in new fridge
make sure the metal bar is in the down position
Apr 16, 2009 | Refrigerators
FRIDGE NO COOL
We will need to unplug refrigerator and open the panel inside the freeze compartment examine the fan for binding and if the fan is defective it will need replaced. Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker stopped dropping ice or even making ice.
Try using a hair dryer to thaw out the rubber tubing leading to the ice tray. On mine, I opened up the front door to the icemaker and found the rubber tubing leading in. I squeazed it, it felt frozen, so I applied heat. Water began dripping out, the area thawed, and I had ice again within a short period of time.
Mar 20, 2009 | Whirlpool ED2FHEXN Side by Side...
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
197 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
