Question about Toshiba Satellite 1805-S204 Notebook
The mouse and the pad are disabled how do I enable without using a mouse?
SOURCE: enabling computer mouse
Use the touch pad arrow to open the touch pad icon in the tray, lower right of screen. The touch pad is right below the space bar.
Posted on Jan 22, 2008
Theknack
  • 144 Answers
SOURCE: Disable Touch pad device
Hi NR5A,
Press Fn+F9 on your keyboard to enable/disable
Goodluck,takecare.
Posted on May 08, 2008
  • 40 Answers
SOURCE: I need to disable touch pad and use a usb mouse
Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
Posted on Sep 28, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Touch Pad mouse not working
Connect and external mouse, then go to Toshiba website and download the touchpad driver for your laptop and reinstall them again.
Posted on Oct 10, 2008
SOURCE: Mouse pad
The program that controls the functions on the pad is called Synaptics. If the small red Icon does not show on your task bar, you can find it in program files. I had the same issue and turned it off. I forgot how I had done it so it took me a while to remember where to go to turn it back on. Right click the icon and go to properties. Then go to device settings and you can disable it or change settings however you like. Hope this helps you.
Posted on Oct 17, 2008
How do I disabled the touch pad and only use an external mouse and the keyboard on the lap top?
You do not have to actually disable the touch pad on this laptop to use an "external" mouse. Just plug in your mouse and it will install the drivers if needed and viola, your good to go. If you insist on disabling your touch pad however, you can do that by double tapping the top left hand corner, when you do this correctly, a little orange light will show and the screen will show a notification the the touch pad is disabled. To enable the pad back on, just repeat the same step you used to disable, and the on screen notification will indicate the touch pad is enabled!
Aug 04, 2011 | Compaq Presario CQ56-115DX Laptop
Mouse pad stalls and i see a little red light on the mouse pad....i have a compaq laptop but not sure what version...how do i disable thi feature so i dont have to use a physical mouse
The little red light is likely from the red LED underneath your optical mouse. If the mouse cursor/pointer on the screen is jerky, it may mean the mouse pad is dirty and/or if the mouse is wireless, its battery is low and should be replaced. Most laptops have a touchpad as part of the keyboard. If you want to use that instead of a physical mouse, just put the physical mouse away and use the touchpad. Both should be active unless the touchpad was disabled. If the touchpad is disabled, you can re-enable it by clicking on control panel > mouse > device settings tab > enable button.
Mar 16, 2011 | Computers & Internet
When my new hp mouse pad locks, how do i unlock it without restarting the computer?
There should be a button above the pad or work your way using the keybord to mouse properties and go to the page that has the name of your track pad and select enable.
Mar 01, 2011 | HP Pavilion dv7-1020us Notebook
My computer comes on opens windows all looks ok as soon as i touch the cursor, nothing responds,
Make sure that the track-pad (mouse-pad) is not disabled. There should be a button located above the track-pad that allows you to disable or enable the track-pad. If not, I would use a USB mouse and then go into the Control Panel, mouse and change settings there to enable the track-pad.
Nov 08, 2010 | Acer Aspire 4720 Notebook
My Dell N4010 Laptop with Windows 7 software indicated a message of "touchpad disabled", and I can not manipulate the mouse.
You are confused. Your touch pad is disabled, but if you plug a mouse into the USB port, your PC will find it and install its software and you will be able to use the mouse To re-enable the touch pad, click on the Windows ball at lower left of desktop, Control Panel, Mouse, Touch Pad, Enable Touch Pad.
Oct 18, 2010 | Computers & Internet
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Hi.my touchpad don't work at all!!I can't do anthting with my touchpad.
The pad may be defective buy a cheep wireless usb mouse for it and use it to work without the pad. the pads do wear out and the replacement would be over a 100 Bucks.
Jan 15, 2010 | Acer Aspire 5100 Notebook
I am using my phone to ask this question.
the touch pad is usually controlled by synaptic.
To turn it on back, press start menu from your key board and scroll to control panel.
From control panel, use the tab button to select the icons on control panel and go to mouse.
From mouse, use your keyboard to control to device settings.
From device settings, you would see synaptics touch pad, then press enable and that's all.
You touch pad would then be enabled again.
All the best.
Jan 05, 2010 | HP Compaq Presario 2200 Notebook
Toshiba Satellite 1805-S204 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
