Maytag washer won't agitate burning smell - Washing Machines
  • meghan06 Aug 24, 2008
    My washing machine won't agitate either, it will fill, spin and rinse, but it won't agitate. Mine is a Maytag MTW5600TQ1 washer. I made it through 3 loads this morning, and now nothing. When it does get to the point where it's supposed to agitate, it makes a humming noise for about a minute and then shuts off entirely. This is followed by a burning rubber smell. HELP!!!
  • luvmyhemi Feb 14, 2009
    I have a SAV2655AWW top load washer which did the same thing within a year after purchasing. Now it won't agitate without making a lot of noisy. It is making a clicking sound, as if something isn't engaging fully.
Take some of your load ou and ,make sure that the washer is not on a delicate cycle, try o resume on regular with less laundry washer should start up again!
Posted on Jan 06, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
ADMIRAL WASHER MODEL NUMBER LNC6753A71 HAS BURNING SMELL AND WON'T PUMP AGITATE OR SPIN BUT MOTOR IS RUNNING
its probably the drive belt that you smell burning under the basket,but there are numerous things that can cause it to burn,so you need to find where its froze up could be a clutch,the brake,the drain pump
Aug 02, 2011 | Whirlpool Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Washer fills with water, loud thump sound, no agitation occurs.
The thump is probably the motor trying to start followed by the burning smell of the belt slipping. See if something is jammed, but the most likely thing there is a bad transmission.
Dec 31, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Will not agitate
Bad pump Pump bearing locked up something up in pump brazzierre underwire shoulder suppet thing IN pump. Check pump
Feb 13, 2009 | Kenmore 63942 Dryer
Washer
THE SMELL IS THE BELT BURNING,YOU CAN REMOVE THE FRONT PANEL TO CHECK THE WATER PUMP,CLUTCH,BELT, AND TRANS,SOMETIMES THE BELT WEARS AND JUST STARTS SLIPPING.,LET MW KNOW-MIKE
Oct 19, 2008 | Maytag Performa PAV3200
Maytag washer
lean the washer back .......
Oct 07, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
1,016 people viewed this question
Top Washing Machines Experts
