Question about Vacuums
Water is leaking out from the water bottle - Vacuums
    Problem Solver:
  • 15 Answers
Ck for broken bottle or the seal in the cap of the bottle.
Posted on Dec 30, 2010
Bissell 7920 ProHeat Upright Carpet Cleaner leaks soap
Just prespray with a pump up sprayer and use unit to extract only with hot water.
Apr 07, 2014 | Bissell 7920 ProHeat Pro-Tech Upright...
When I put the clean water bottle on water pours out of the bottom. A little water has always come out but it is now pouring out. I tested my water bottle which seems to be okay. What is the problem?
I have the same problem with mine. I did the chat thing at the Eureka site, but the info wasn't helpful. There is a little part that opens the bottle to release the water when the handle is squeezed. I don't know if that needs replaced or if there is something stuck in the handle grip or ??? I am only putting 1 gallon of water in the tank, so it is not over-full. It is tap water. I live inside a city and have soft water. I don't think it has anything to do with the upper tank, though.
Mar 05, 2013 | Eureka 2576A Steam Vacuum
What type of water to use RO vs Bottled water I thought RO is the best to use
Yes, RO is definitely the best form of water while bottles is debatable.
Jul 15, 2011 | Vacuums
After putting a new bottle onthe water cooler it leaked brand water max
Sometimes the bottles might have a crack in it which prevents the suction within the bottle and they drain out. Try another bottle, if you get the same result, you will have a leak in your holding tank. If it is less than 30 days old, take it back. If not, the parts and labor are not worth repairing...replacement is needed or more cost effective.
Mar 06, 2011 | Vacuums
I own a watercooler 4 yrs old model # whkmd30The bottle water get extremely hot. There is good ventilation Any suggestions
Your water cooler has a Hot water section, also-- correct?-- You have 2 faucets, right?-- One COLD and ONE hot!
Is it possible that the section that does the HEATING, is stuck ON and is in some way heating the water back up thru the connection, into the big bottle?
Another possible thought: Is there a heater to prevent freezing of the bottle?-- Maybe it is stuck ON
Note: Your question ended up under Vacuums-- We are just trying to help-- Feel free to re-list your problem up there where water coolers are-- OK?
Sorry we couldn't be more helpful here in the Vacuum cleaner area-- :-)
Mack B
Jan 29, 2011 | Vacuums
FHow much solution goes in first?
The tank is labeled. Take the clean/solution tank off the vacuum by lifting it straight up. Unscrew the black cap on the bottom of the tank and remove the bottle insert. Add 8 oz of the Little Green formula (this gets you up to the Formula fill line). Then add hot water to the water fill line. Replace the bottle insert and tighten the black cap. Then replace the clean/solution tank by lining the indentations up with the vertical guides on the left side of the unit and sliding it straight down. Please note that the bottles of the formula come in 32 oz or 64 oz bottles. So you can expect one of the smaller bottles to last 4 fill cycles.
I hope this helps.
Oct 07, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Checked all the hoses and didn't find a clog. Water will not come out of the bottom nor the hand tool. What else could be wrong?
Check the red gasket on the formula bottle. if it is not on the end of the bottle but is stuck in the bottom of the hole than it will create a air leak.
Sep 21, 2010 | Bissell 9200 Upright Vacuum
Older style ....no water coming out...did clean all hoses...
The first thing you need to do is tip the vac up on its back and have a good look at where the water/detergent comes out of, you should see several little jets running along the bottom of the vac right at the front, now what you need to do is get a long pin and give all of these little jets a good poke with a long needle make sure you do this to all of the jets.
Once you have done this sit it back up right and give it a try, you may need to hold the trigger down for 2 or 3 min to let the water/detergent work its way through the vac.
If how ever it still dont work then empty the detergent/water bottle and fill it with hot but not boiling water and add a couple of table spoons of salt now put the bottle back on the vac and leave it for 3 or 4 min then switch is on and hold the button down again for 2 or 3min. Now the hot water and the salt should have broke down any build up of gel that the detergent has turned into over time.
Repeat this process 2 or 3 times to give it chance to work its way around the vac.
After doing this check the jets again and poke with a needle as the chances are the blockage has now moved and is by the jets, now give it another try.
Now if you never found the blockage empty the water/detergent bottle and check where the water comes out of the bottle into the vac you should be abe to press it and see if the water flow freely out of the bottle. if it does then you need to check the part of the vac where this bottle attaches to, their should be some sort of filter where this bottle fits so have a look their and clean with a pin if blocked.
If you find no blockage then try again with the hot water to rule out 100% blockage being the problem. if you have checked and their is no blockage then this would indicate a problem with the pump or a blockage in the pump, now as the pump is not a serviceable part you cant take it apart and clean it so the only option you have is keep trying with hot water or replace pump( check any warranty before you do any work yourself)
The hot salty water should work but make take several tries until it breaks down the gel build up.
Now what they should have told you when you purchased your machine is that after every use empty the detergent bottle and fill with clean warm water and then let this run through your cleaner, you need to do this as if you leave the detergent in the bottle and leave it in the pipes inside the vac then what happens is that over time the detergent turns to a gel so making sure the detergent is gone will guarantee the vac will work the next time you want to use it
Courtesy- Pauldonp
Jun 26, 2010 | Vacuums
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
20 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
