Question about Nintendo Wii Console
Not taking the disc
I have a Wii and it will not insert the disc.. It will only go about a qauter in? Is there a way or a place to get this fix??
  • 26 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Feb 25, 2009
How to troubleshoot the wii
  • The Wii console is only compatible with Wii and GameCube discs. It is not compatible with DVDs or discs made for other home consoles. Verify that the disc you are inserting is compatible with the Wii system.
  • An error message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • Verify that the console is placed correctly.
    • If the Wii console is lying flat, the game disc slot should be above all three buttons and the SD Card slot.
    • If the Wii console is standing vertically, the power button should be on the top and the console should be in the stand. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically.
  • Verify that the disc is being inserted properly.
    • If the console is placed horizontally, the disc label will face upwards.
    • If the console is placed vertically, the disc label will face to the right.
  • Check the non-printed side of the game disc for dirt or severe damage (such as scratches or cracks).
    • If the disc is dirty, try cleaning the game disc.
To clean disc:
  1. Dampen a clean, soft, cotton cloth with water.
  2. Use straight strokes and wipe the disc (non-labeled side) from the inside rim to the outside rim.
  3. Using a dry part of the cloth, repeat step 2 to dry the disc.
  4. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Wii console.
If the disc is damaged or scratched, it will need to be replaced or you can possibly taken it to a game store or movie store to get it resurfaced (buffed)
Apr 25, 2013 | Video Game Consoles & Games
Not taking the disk in
The most common reason for the Wii not taking discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your Wii including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your Wii going again!
Hope this will help...
May 31, 2010 | Nintendo Wii Console
I think my son has put something in the wii as it was working fine but now when i insert a disc it makes a buzzing noise and ejects the disc???
you may need to get a trigram screwdriver to undo the funny screws in the wii and take a look, mine had a piece of paper in it and it sometimes stopped discs coming out.
Sep 10, 2009 | Nintendo Wii Console
My wii won't take the disc
Apr 06, 2009 | Nintendo Wii Console
Cannot read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide...
Mar 29, 2009 | Nintendo Wii Console
Wii wont accept disc
Go to the section on "screw types" to find the unique screw that was used to on the Wii. It's likely to be torx. T3, T4, T5, T6.....
http://en.wikipedia.org/wiki/Screw
Then from there, you can go to an electronic store.
Dec 27, 2008 | Nintendo Wii Console
Takes in disc and then spits it out
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 24, 2008 | Nintendo Wii Console
Unable to read disc error
If Wii gives Unable to read Disc Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Nov 10, 2008 | Nintendo Wii Console
Makes noiae when inserting disc or game and it wont eject
to save taking it apart and losing your warranty find a fully licensed repair shop to get it sorted, or if you havnt had the console for too long phone up sony if thats your console type and they will pick it up for repairs
May 03, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
