Question about Sony KP-51HW40 51" Rear Projection Television
Red Screen I read through all the questions and responses and couldn't find the same problem my tv is having. the entire screen is red when i turn it on, i can faintly make out the menu screen, the color and brightness controls don't do a thing. i tried resetting and unplugging the tv for 15minutes and that didn't help at all
  • 4 more comments
  • tnbill66 Jul 08, 2008
     Sony mod #  KP-57WV700   rows of small red angled lines when screen firs lights up, then flashes red background in picture, was workinf fine when turned off night before.
     Any ideas
     Thanks in advance
  • yz917f Jul 09, 2008
    when i start the tv the picture looks fine for a second, then red horizontal lines form for a few seconds then the whole screen goes red. the front light under the screen flashes 5 times. no diagnal lines though...
  • milo516 Jul 18, 2008
    screen goes red then completely black light flashes 5 times. Unplugged set for couple of hours still does it. please help.
  • ShineonWCS Jul 26, 2008
    Sony KP-51HW40
    Arched, thin red lines. However recently, after TV is turned on, it slowly fades to ALL red then turns itself off. Stand-by light blinks 5 times. When the ALL red event first happened, It was proceeded by a slight audible "pop" sound.
    Had the red lines, etc. Just fixed my Sony KP-51hw40 51" TV using these instructions.
    http://www.somelifeblog.com/2007/06/sony...
  • echoside2002 Feb 08, 2009
    I got the tv from someone who didn't to fix it. I turn the TV on and it is a blood red screen. That sometimes fades back o noramal then flickers back to red. Please help!!! any solutions greatly appreciated!!! Thanks
Yes I have the lines and the red screen
Posted on Jul 25, 2008
  • Sony Master
  • 8,617 Answers
Are their little thin red lines kind of on an angle along with the red screen ? Please respond to this same post, I may be able to help you with the problem.
Posted on Jul 08, 2008
2 Suggested Answers
  • 2326 Answers
SOURCE: Red Screen
There is some information on how to fix the failure on your TV. Click here to find the how is done, but be very careful about the high voltages surrounding the circuitry. If the adjustments do not work then you could probably will have a defective red tube or a video amplifier IC on the red CRT board.
Let me know if you need further assistance.
Posted on Aug 20, 2008
LG 42CS460 THE SCREEN HAS TURNED A RED COLOUR
sounds like a problem with the color circuit in the set, possible fix: Problem is that the connectors for the ribbon cables to the mother board are getting oxidized. All of the ribbon cables have to be removed and the prongs cleaned off. That cures the problem! I tried to do it myself but there were too many screws and panels, so I took it to a local TV tech and told him what to do and he did for $48. He said they all showed various degrees of oxidation but the main one was the worst, so it made sense that it was impacting the color image.
Read more: What if your TV screen turns red - What does it mean when the screen on your tv turns red then shuts off :: Ask a Question Get an Answer For Free ' FuriousTee at http://www.furioustees.com/What_if_your_TV_screen_turns_red-qna151606.html#q39143
Nov 21, 2014 | LG 42CS560 42 Class LCD HDTV
Red tint to screen
If the model is a 50v500 the real question should be does the set have a red oval area in the middle of the screen (entire screen not red)---if the entire screen is red you have a chance---it has a red oval area and it needs a new optical light engine----you will have options also but limited if that is the case.
Aug 26, 2012 | Hitachi 50V500 50 in. HD-Ready LCD...
I haveMy compaq presario CQ40 and my monitor screen got flicker always for past few days and more red horizantal lines @bottom of the screen, where i couldn't see the data,time,date... Plz help me...
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Sep 02, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Red red wavy lines across the TV screen
I did not fix the problem, but you have the model number wrong, it is KP-46WT510
I do need some help.
Nov 23, 2008 | Sony KP-43HT20 43" Rear Projection...
RED SCREEN
hell yeah,
the biggest mistake I did with this tv.all tubes need to be replaced and it burns a hole in ur pocket.no guarantee on tubes,sony aware of the problem but didnot recall these defective sets.
good luck.
nanz
Oct 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Red Screen
Aug 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony 65 inch screen tv
The lines you saw, i;m sure they are the ones called retrace lines but know the failure could be located on the red CRT board. Most likely the video amplifier is defective and not necessarily the CRT.
What is the model number of your TV?
Jun 17, 2008 | Televison & Video
Yes the red tube is shorted. I will post a link to the site where I work as they have an entire AV48WP30 with a bad tuner they are selling parts off of including the Tubes. they also provide free info on how to switch out the tubes as a unit which is a fairly easy job. Heres the link.
http://servicemanuals.vstore.ca/
May 21, 2008 | JVC AV-48WP30 48" Rear Projection...
Red CRT is dim....
Yes I did. You will need to get a service manual for this TV set to trace the voltage coming from the sweep power supply. If this is a problem that is new after you replaced the convergenbce4 board, you for sure have a broken wire or connection somewhere in the set. Have seen this happen may many times after a novice repairs a TV set. Good Luck
Sep 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Red Horizontal Lines On Screen
Sounds like the DMD board, I would rather have Samsung to do the in home repair
Dec 27, 2006 | Samsung DLP HL-P4663W 46" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
257 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
