Question about KitchenAid 24 in. KUDS25 Built-in Dishwasher
After filling and only when rinse commences a loud chattering noise begins. Somewhat like a circuit breaker making intermittent contact. It ends when I cancel and remains silent while the pump empties the washer. Any ideas? David
    Problem Solver:
  • 6 Answers
  • It sounds like you have an obstruction with upper or lower spray arm. check to see if the something is stuck in the path of the lower spray arm.
  • move the lower rack out
  • spin the spray arm by hand to see if it is hitting anything
  • if not .....spin the upper spray arm by hand under top shelf to see if it is hitting anything.
  • let me know how this works
Posted on Dec 31, 2010
Crackle noise at loud volume
We will need more info to help you. Make and model of the problem gear, etc. Most noise problems are caused by dirty contacts in the jacks or intermittant solder joits in the circuit.
Feb 01, 2016 | Music
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Our dryer was making a loud squeaking noise for a while now it is tripping the circuit breaker as soon as it is started what do you think is our problem.
The drum rides on a bearing in the rear which cause the squeal. The squeal eventually cuts into the bearing and the whole drum begins to rub against the heating element. This causes the breaker to trip.
How it works: GE clothes dryer
Jan 05, 2011 | GE Dryers
Loud grinding/scraping/rattling noise at rinse cycle
The balance sensor is likely failed.
Check the shock absorbers and springs for breakage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Dishwashers Logo
124 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
