Question about Phoenix Gold "Mt 007" Motorized Treadmill from Phoenix Health & Fitness
My body sculpture mt007 treadmill gave a bang and stopped working. I think it needs a new motor. Do you know how/where i can get this fixed and how much it is likely to be as am considering buying a new treadmill instead. What do you suggest. Thanks Dawn.
Need info on error code 02 on my body sculpture treadmill 5700
can only suggest you contact the manufacturer with your query
Mar 24, 2017 | Body Sculpture Exercise & Fitness
Body sculpture BM1505 is it possible to purchase the fixing items for the handle
Depending on how old the unit is. There are places where you can buy parts or you can visit www.body--sculpture.com and email them for the parts you need. Otherwise, if you're lucky someone is getting rid of his and you can rescue it for parts. Try the company first.
Dec 28, 2014 | Exercise & Fitness
My BT3152 treadmill has stopped working, the belt no longer moves
Is anything jamming the belt or motor drive pulley? Look carefully for anything that could be jamming it. If you suspect the motor could be bad, take it electrically out of the circuit and connect it directly to the your power supply, if it spins up you know its working, however, it could still be tripping off when under load.
Nov 09, 2014 | Body Sculpture Bt3152 Motorised Treadmill
Body sculpture BT5810 motorised treadmill. My treadmill switches on normally but after the 321 countdown to start error E1 is displayed and the belt does not move at all. Appreciate any advice you can...
see the step attached. clean the s. sensor , and diagram attached.
God bless you
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.afb1d921-a008-4e96-876a-cd31ffa20ecf.gif
Oct 31, 2013 | Body Sculpture Bt3152 Motorised Treadmill
There is a tapping noise when I run the treadmill
hi,
if you didn't lubricate the treadmill the try to do that first. if treadmills are not properly lubricated in time they will make noises and will cause problems for running belt and motor . check the video to know how to lubricate the treadmill.
if you would like to know more about treadmill regular maintenance then check the link bellow.
Treadmill regular maintenance
Oct 27, 2013 | Body Sculpture Bt3152 Motorised Treadmill
Body sculpture treadmill runs for 6 seconds then stops
1( LUBE the deck belt, this happen because the lack of maintenance
2( LUBE the rollers bearing too.
3( test the input voltage motor, if there are the motor need repair.see my personal TIPS
4( test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Oct 07, 2012 | Body Sculpture Bt3152 Motorised Treadmill
Body sculpture BT2710 instructions
hi if you email body sculpture on sales@hi-markgroup.co.uk they will send you a free manual by pdf they are brilliant i know because i have used them for the same reason myself last week
Jules
Apr 08, 2009 | Exercise & Fitness
Phoenix Gold "Mt 007" Motorized Treadmill from Phoenix Health & Fitness Logo
140 people viewed this question
Top Phoenix Gold Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Phoenix Gold Exercise and Fitnes Expert? Answer questions, earn points and help others
