Question about Sherwood SR1 Regulator
New SR1 has not been used yet. When you turn on air pressure; there is a loud screeching noise and air comming out of the plastic ring in the center of first stage.
  • 50 Answers
Did you have this regulator shipped to you or did you pick it up personally at a scuba store ??
Posted on Jan 04, 2011
Car makes very loud screeching noise.
It could be that the air conditioning compressor clutch is not working properly. The clutch should allow the pully to freewheel when the air conditioner is not used.
You can have your battery tested at.an auto parts store, and you can test the alternator by removing a battery cable while the engine is running. The alternator is what powers all the electrical systems while the engine is running. If the engine stops running when the cable is removed, this means that the engine was running from the battery and not the alternator.
Your alternator or your regulator is bad.
Regulators are an internal part of alternators, unless its a pre 70's.car where they were a separate external unit.
Hope this is helpful.
May 04, 2016 | 2001 Pontiac Firebird
When the tub is turning it makes a loud screeching noise. The more laundry in it the louder it will screech.
needs these plastic tub rubbers can get at service store for very little money they snap in very easy to do
Aug 27, 2011 | Dryers
Turning on hot or cold water I get a loud screeching noise and very low pressure. If I keep turning the handle, I can get rid of the noise, but still low pressure.
It sound like you have sediment blocking your valve, faucet airiator or shower head (depending on what you're using). FYI: if it turns out to be defective all Moen faucets and showers have a life time warantee.
Jun 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Screeching when steering
If The Noise I Coming From Under The Center Of The Car You Have A Bad Rack & Pinion
Jul 11, 2009 | 1994 Ford Thunderbird
Loud screeching noise coming from car after stops.
the screeching noise is most likely caused by a slipping belt or pully. transmission probably needs fluid and filter changed.
Jun 02, 2009 | 1990 Ford Tempo
Loud screeching noise coming from the unit.
A screeching or squealing noise usually comes from the fan motor. There may be an oil port and you can buy a small telescoping oil bottle at a super hardware store or an a/c supply house. Before putting in he oil, remember to TURN OFF THE POWER TO THE UNIT and only use a light squeeze on the bottle - over oiling will cause a mess inside the motor. It may be a sealed motor and no oil ports. In either case, budget for a new motor as if it's to the squealing stage, the bearings are already damaged and it's a just matter of time before before the motor bearings fail. If possible, get oil on the bearings ASAP - and use the proper lightweight oil for made for this application.
May 05, 2009 | Amcor PLM16000 Portable Air Conditioner
Mine is a FDB635RFS4 model - issue is loud screeching noise
i recently had the same problem of a loud screeching noise. my unit was installed new in 1999 and has worked well up to this point.
when i disassembled the tub water filter i found the filter was heavily clogged (it is supposed to be self cleaning), and i also found glass shards from a broken wine glass. i further disassembled the plastic housing under the filter ( held in place by three torx drive screws ) which covers the pump impeller and holds the lower spray arm. while i did not find any blockage in the pump area, and no abnormal sound when i turned the impeller by hand, i did find that one of the pump impeller vanes has a small chip which probably makes the impeller unbalanced resulting in more than normal vibration. i cleaned the water filter and reassembled the parts and the original screeching noise is now gone.
Sep 03, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Sherwood SR1 Regulator Logo
125 people viewed this question
Top Sherwood Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Sherwood Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
