Question about Lexmark X464DE Mono Laser MFP, 38ppm A4 Mono, Print/Scan/Copy/ Fax, Duplex, USB/Ethernet Interface, ... All-In-One Printer
I'm getting a grinding noise when printing on lexmark x464 also intermittent 31.04 missing or defective toner warnings and replace pc warnings even thoguh photoconductor has been replaced. I ruled out redrive and fuser assemblies.I've also rpelaced both the photoconductor and the toner cartridges. I'm looking at the main drive gear assembly. any suggestions?
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Photoconductor and error 537
Perhaps a copy of the parts diagram and/or the multi part service manual might be of more help.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
  • 217 Answers
SOURCE: error 31 lexmark e350d
Possible causes here are;
Most likely, the contacts in the printer not touching the chip properly (hence why it works in another printer). A simple gentle 'tweak' would work in this case.
The other possibility is the firmware version of the (offendig) printer being incompatible with the version of the after-market chip you are using. No solution here, other than trying a DIFFERENT MAKE of chip.
Posted on Apr 05, 2010
Joed911
  • 4338 Answers
SOURCE: I have replaced my photoconductor
Try:
To restore factory defaults:
1. POR the machine into Configuration Mode.
2. Use the down navigation button to scroll to the RESTORE
FACTORY DEFAULTS item on the menu.
3. Press Select. The machine performs a POR.
4. The RESTORE FACTORY DEFAULTS sets the MFP non critical
parameters back to the factory settings.
Note: Some settings are not affected: panel language, energy
conserve, paper prompts, registration margins, and page count.
Posted on May 20, 2011
Lexmark 352dn 31 missing or defective cart
The 31 error message means that the printer is detecting the toner cartridge is either faulty or not installed properly. You might need to replace your toner cartridge.
Nov 12, 2012 | Lexmark E352dn Laser Printer
Grinding noise
could be the laser unit on top of the printer out of whack -i have the same fault also
Jun 29, 2012 | Lexmark E120n Laser Printer
I refilled toner of my Lexmark E120 (since it said it was out of toner) and it worked fine untill few days ago when I got status report: Missing or defective catridge. Could this mean it's out of...
Replace the chip, is a chip cartridge problem.
if not work try this:
31 Defective toner cartridge or missing cartridge
1. Verify that the toner cartridge and PC kit are correctly installed.
2.Wait 10-20 seconds for the printer to verify the units.
3. Replace the toner cartridge or PC kit if necessary.
Aug 01, 2011 | Lexmark E120 Laser Printer
I have replaced my photoconductor in my Lexmark x464 and I still have a warning notification comming on. How do I reset it?
Try:
May 20, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Power up init fails
When you replaced the photoconductor, did you go through the procedure to reset the photoconductor counter ?
There's no chip on the photoconductor, so you need to reset this manually
Photoconductor Reset Procedures:
Step 1:
Open the front door and hold the
Cancel button until all lights begin to cycle.
Step 2: Close the front door. The warning
clears and the counter resets to zero.
Step 3: Press Continue to resume printing.
Mar 01, 2010 | Lexmark E120n Laser Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
Lexmark C720 grinding noise & fuser damage
From the site of your Picture, you need a new fuser unit.
The coasting is peeling off... that is not good. And I will bet you get allot of paper jams.
To replace the fusing unit is not hard to do. For the most part taking the covers off the machine and getting them back on is the hard part... Let the fuser unit cool down before you touch it..
Just remember to unplug the machine, Electronic Static Discharge is not good for the Boards in it, touch the metal chassis before you touch the boards if you don’t have a wrist strap) get your self a table and some room to work and take your time.
Take the toner cartridges out
I would do a maintenance kit while I had it apart. (rollers, transfer rollers etc)
Vacuum it out; clean it while you have it open.
(Warning toner and developer is very fine, you might need a vacuum with a micro filter on it, other wise it might go every where)
The service Manual has details on how to do all this. If you follow that you should be ok.
You could try to get all the parts to Fix the fuser unit, but it is easier and faster, cheaper to replace the whole thing. Some places offer a core exchange.
If you need any assistance let me know...
This is from Lexmark
http://www.lexmark.com/lexmark/product/home/605/0,6970,204816596_846034106_306769501_en,00.html?tabId=1
These are various other places that offer parts and supplies.
http://www.innovone.com/~tsa/
http://www.all-laser.com
http://www.p2gcentral.com
http://www.precisionroller.com
Oct 27, 2008 | Lexmark C720 Laser Printer
Lexmark C510 Laser Printer- Grinding Sound on startup and while printing
Thank you Krissy! I had the same problem with the horrible grinding noise.
I took out all of the toners and the photo developer and noticed that my Blue toner was leaking all over. After reading your post, I tried replacing the toner. It worked!!! No more noise - and no more mess!
Jan 30, 2008 | Lexmark C510 Laser Printer
Makes grinding sounds & usually prints blank
Try new toner cartridge, or even the old one if you still have it. Check if the grinding noises go away.
Jul 06, 2007 | Brother MFC 6800 All-In-One Laser Printer
Lexmark X464DE Mono Laser MFP, 38ppm A4 Mono, Print/Scan/Copy/ Fax, Duplex, USB/Ethernet Interface, ... All-In-One Printer Logo
156 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
