Question about Dell 1815dn All-In-One Laser Printer
I have a Dell 1815dn all-in-one laser printer. I have a "open door front door' error message rendering my machine inoperable. Any suggestions on how to clear this?
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Hey, make sure the front door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS.
Posted on Jun 16, 2011
2 Suggested Answers
StevenC82
  • 160 Answers
SOURCE: Front door open message on display of dell 1815dn printer
Hey, make sure the front door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
How do you print an envelope on a Dell Laser MFP 1815dn
when printing enevelopes always ALWAYS THROUGH THE BYPASS open front door and feed thru there. on the bypass is image to let you know fce up or down follow that. also change settings on pc when printing envelopes or cardstock etc.
Jun 09, 2012 | Dell 1815dn All-In-One Laser Printer
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
Door open Front door message. the copier does not work
plz check the printer carefully, there may be some dislocation of some parts which is preventing the front door from completely closing. post back if more assistance is req.
Aug 12, 2010 | Dell 1815dn All-In-One Laser Printer
I have following message "Door Open" and "Front Door" in the Dell 1815dn All-In-One. I checked that door is properly closed, then I checked sensor and press it by clipper, message is still coming out. I...
This message is usually down to thesensor on the HVPS. Firstly check that the switch related to thefront door doesn't have a blue cover on it. (Some call out techsreplace the HVPS and leave the switch cover on). Removing the RHScover firstly (4 screws) and then removing the arm that toggles theswitch (1 screw) should allow you to see if the switch has a coveron it. If this is ok then you would need to take apart the HVPS andclean the sensor and if this still doesn't help then replace the HVPSboard..This will take some time to do so a good read of the manual isrecommended.
Jan 25, 2010 | Dell 1815dn All-In-One Laser Printer
Dell 1815 dn - bogus front door open message
Sep 08, 2009 | Dell 1815dn All-In-One Laser Printer
Front door open message it won't print
There is a switch inside the front door that is not making contact when the door closes, making the printer think that the front door is open. The switch is recessed in the housing. Look for a plastic knob that protrudes from the front door that will mate with a hole in the frame. Inside this hole is the switch. Try activating the switch manually with a screwdriver to make sure the switch is functioning. If it is, you will need to take off the cover and reposition the switch forward. If it does not activate manually, the switch must be replaced.
Jun 22, 2009 | Dell 1815dn All-In-One Laser Printer
'user door open' error -where is the 'user door'? We have opened and closed all the parts we can find that open and close.
the door you open to put the cartridge. If the door is closed and you still get the message, it means the door is not activating the microswitch when the door is closed. There must be a tab on the door which presses the switch.
May 22, 2009 | Dell 1815dn All-In-One Laser Printer
May 21, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn says Open Heat error. How do I determine if the fuser or the power supply is the problem?
This is usually a problem with the fuser. Iteminc.com has these in stock and ships same day. Hope this helps any1 with this error. Good luck!
Apr 01, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
278 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
